Old 24-07-09, 05:31 PM   #1
cammy
Default Side stand cut out switch
Does the switch just lie inside the frame or does it clip onto some kind of bracket? As theres a bit on the connector as if something else goes onto it.
Old 24-07-09, 10:46 PM   #2
Default Re: Side stand cut out switch
I haven't noticed a bracket on any I've worked on, on the connector.
Make sure in front sprocket area it is tucked away and not likely to get eaten by the chain though. There is a plate with tabs, and a flexible metal clip IIRC.
Old 25-07-09, 02:24 PM   #3
cammy
Thanks its just the parts drawing shows a clip on some models inside the frame so i thought the connector might have hooked onto it thanks Cammy
Old 25-07-09, 02:33 PM   #4
Rob969
you could use cable ties to secure it to something if your worried its to loose.
Eliminating side stand switch … Diode Blue_SV650S SV Talk, Tuning & Tweaking 14 28-05-08 11:47 AM
Side stand switch. derbybiker SV Talk, Tuning & Tweaking 4 19-04-08 11:58 AM
Bypassing The Side Stand Switch squirrel_hunter SV Talk, Tuning & Tweaking 10 23-06-07 09:50 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Side stand switch jonhunt SV Talk, Tuning & Tweaking 2 15-01-07 11:37 AM
