Old 25-07-09, 07:10 PM   #1
davepreston
Question gear change without using left foot
is it possible to do a cheap modification so i can change gear without using my left leg
its been 2 days and im annoyed already and know i cant last 10 weeks without riding
this is a serious enquirey so no b0ll0cks people
Old 25-07-09, 07:12 PM   #2
Alpinestarhero
Default Re: gear change without using left foot
not really, unless you can work out some sort of hand lever to shift the gears. Otherwise, your looking at expensive electronic systems
TBH, it may be best just to stay of the bike until you are healed. The lack of machine control and concentrating on another method of changing gear would make you prone to more accidents
Old 25-07-09, 07:13 PM   #3
Razor
Thumb lever for rear brake and then you need to make a linkage to run under the bike for a RHS change lever, brackets modified to suit natch. Did one years ago for a mate with no left leg.
Old 25-07-09, 07:25 PM   #4
rictus01
rictus01's Avatar
been there, looked into the whole thing, through need, basically you'll need either an air shifter or solonoid shifter, I was looking to pair it up with an ignition interupt as well, but standard clutch would do, kliktronic were the one's I was seriously contenplating, but not cheap.
HTH
Cheers Mark.
Old 25-07-09, 08:40 PM   #5
Dan
I was thinking something along the lines of a rod to the end of the lever, run up the side of the frame to a pivot mounted somewhere near the knee, and a right angled bend to a hand change somewhere up by the tank.
Old 25-07-09, 08:42 PM   #6
davepreston
like a chopper suicide shift you mean
Old 25-07-09, 08:43 PM   #7
Dan
Basically. It's nothing that hasn't been done a million times by people like OCC.
Old 25-07-09, 08:56 PM   #8
ethariel
ethariel's Avatar
Could try enquiring to NABD they prolly have plans you can use.
ethariel is offline   Reply With Quote
Old 25-07-09, 08:58 PM   #9
Richie
fantabulas
Richie's Avatar
this is a serious enquirey so no ball talk people
Buy a Vespa... smallest one I could find... + purple urine
My Flickr photos
Old 25-07-09, 09:53 PM   #10
orose
Following up on Richies point - isn't this accident related?
Hire bike (Mana) or super scooter until the leg works enough to work the shifter perhaps
Foot Gear lever for pointy Warthog Stuff Wanted 4 18-02-09 04:41 PM
Left hand side foot-rest hanger mikebrooman Stuff Wanted 0 19-11-08 03:00 PM
k5 pointy left footpeg, gear changer assembly and left front indicator - will pay good money Paul the 6th Stuff Wanted 2 21-04-08 09:03 AM
Gear Selector Foot Peg T0mm0 SV Talk, Tuning & Tweaking 17 10-08-05 02:38 PM
