Old 27-07-09, 02:47 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default choke plungers - should that happen?
the rear plunger assembly is corroded so much the cable couldn't pull it out, the cable was rusted and so brittle that is snapped trying to pull out the plunger
the plunger itself is ok but the spring is rusted to hell didn't think anything in there should rust
05 DRZ400E
RIP hovis
Old 27-07-09, 03:00 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: choke plungers - should that happen?
When I took my carbs apart because the choke was stuck open, the springs were rusty, and the plugers were stuck in the carbs to...
The cable was really rusty as well. If you pack the splitter in the choke cable with grease apparently it stops this happening as it stops the water running down the choke cable.
I dont know if it actually solves it as I sold my SV soon after fitting the new choke cable.
Old 27-07-09, 03:42 PM   #3
Wideboy
Evel Knievel
Wideboy's Avatar
the spring in the in the front pot was fine and so was the plunger, in fact the spring shot off across the garage and is now lost , but the rear pot is in a hell of a state and the spring is so rusty its stuck in the plunger housing
05 DRZ400E
RIP hovis
What will happen to the org? NAPA121 Idle Banter 35 18-10-08 05:58 AM
choke cable with springs plungers etc husky03 Stuff Wanted 0 09-02-08 07:39 PM
Choke Plungers ELR4ever SV Talk, Tuning & Tweaking 7 07-12-07 12:06 PM
it had to happen one day kwak zzr Photos 30 05-10-07 03:39 PM
Is this still going to happen? mysteryjimbo Rideouts & Meetings 2 11-02-05 05:17 PM
