My chain has become a bit loose today and I'm wondering if this has caused the problem I had today and have had before
When I'm slowing down using engine braking, in 3rd gear I think, the engine sort of judders then it's fine, then judders, then it's fine ...... etc Is that caused by the slack in the chain? |
Is the chain now at the correct tension?
No I haven't tightened it yet. It doesn't do it all the time. I'm pretty sure it's the chain causing the problem but want to confirm it. Is there was anything else that could cause the problem
#4 | |
Likely it's the chain.
Nevermind
Did it sort it?
yup.. sounds like backlash... or you are putting the throttle on and off unaware, i sometimes do it going over bumpy roads.
if its happening at low revs then i would suspect its chain slap/backlash. |
Loose chain - advice needed asap please :) | El Saxo | SV Talk, Tuning & Tweaking | 7 | 21-09-08 05:06 PM |
Loose Chain | krhall | Bikes - Talk & Issues | 32 | 21-05-07 11:09 PM |
how dangerous is loose chain? | New Leaf | Bikes - Talk & Issues | 35 | 25-01-07 07:34 PM |
Wheel spinning / Chain loose / Bike fewked? | _Stretchie_ | Bikes - Talk & Issues | 12 | 04-05-06 08:08 AM |
Loose Chain - Tightening? | Daimo | SV Talk, Tuning & Tweaking | 7 | 17-02-06 01:46 PM |
