03-08-09, 02:56 PM | #1 |
Weepy clutch cover
My curvy has it. Always had it. Never really bothered me but i am starting to get fed up of my belly pan getting fully of crap after a while and have decided its probably better just to sort it out. Any tried n trusted methods to fix this out there?
03-08-09, 02:59 PM | #2 |
Re: Weepy clutch cover
you can just buy a new big o-ring that goes inside it.
Be careful doing it up as it is only plastic the clutch cover. |
03-08-09, 03:00 PM | #3 |
p.s lean it over far enough and you don't need to drain the oil!
03-08-09, 03:04 PM | #4 |
Really? I always though it was a bit more than just replace the o-ring..
03-08-09, 03:14 PM | #5 |
well it depends I've had two sv's and just the o-seal has solved it,
if its warped then thats a different matter - you can put it on a very flat surface to determine that. My first one went because the dealership over filled it. |
03-08-09, 03:34 PM | #6 |
Vipers Pillion Bitch
Once it leaks it'll leak forever if you don't replace the whole lot IMO. The plastic clutch cover warps and that's it. I got a new Suzuki genuine seal which I seem to remember being horrendously expensive for what it was and used blue Hylomar gasket seal and torqued it all down and it still ended up leaking again.
I look good, I mean really good! Hey everyone come and see how good I look! |
03-08-09, 03:39 PM | #7 |
Mine's weaping also sheila, we mighty do a job on them
03-08-09, 03:44 PM | #8 |
The cover on my 1st SV weeped, bought a 2nd hand cover off someone on here, but as said before it is only made of plastic so dont overtighten it or it will warp again
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA |
03-08-09, 04:21 PM | #9 |
Its about 56 quid for a new cover, I had this problem tried changing the o ring twice along with adding blue sealant.
Ended up buying a new cover/ o ring and it hasn't leaked since |
04-08-09, 11:51 AM | #10 |
Sounds like a new cover job to me!
Thread Tools | |
bloody clutch cover | AndyBrad | SV Talk, Tuning & Tweaking | 42 | 03-03-09 08:22 PM |
Clutch cover 01 Curvy | jumjum_0214 | Stuff Wanted | 9 | 10-10-08 05:08 PM |
Clutch Cover | carsounds_dan | SV Talk, Tuning & Tweaking | 17 | 12-06-08 04:27 PM |
Clutch cover. | scottjames | SV Talk, Tuning & Tweaking | 8 | 16-04-08 11:30 AM |
cracked clutch cover | alka | SV Talk, Tuning & Tweaking | 3 | 28-06-05 09:34 AM |
