Old 04-08-09, 12:42 PM   #1
Geodude
Geodude's Avatar
Default Lethargic starter motor
Dont know why but sometimes when i start bike (sv650 99 naked) i get a very slow few turns on the starter motor which sounds like a flat battery or stuck starter and the bike wont start, but if i try again after a few minutes it works as normal sometimes wether bikes hot or cold? Im stumped as to why or what is the problem. Only had bike a month so the whole DIY mechanic stuff is new to me Any ideas anyone?
Old 04-08-09, 12:44 PM   #2
thedonal
Default Re: Lethargic starter motor
I've started getting the same thing. The starter may need an overhaul. However, mine was done last October- I would have thought it'd last a little longer than 5,000 miles between overhauls- though it's an old unit (1999 SV).
Old 04-08-09, 12:51 PM   #3
Geodude
Geodude's Avatar
Cheers for quick reply at least i know im not the only one with the problem. TBH ive so far spent more time fixing than riding since i got bike a month ago.
Old 04-08-09, 12:53 PM   #4
Spanner Man
Good afternoon all.
It could also be a dodgy solenoid, the internal contacts could have an could be somewhat burnt, therefore causing an intermittent contact.
Try bypassing the solenoid next time it happens. Use a hefty piece of metal, or a jump lead clamp between the solenoid contacts. If it cranks ok then it's probably the solenoid at fault.
Cheers.
Spanner Man
Old 04-08-09, 01:09 PM   #5
Spiderman
Where the hell am I?
Spiderman's Avatar
Obviously i bow to spanner mans wisodom on these things as my mechanical knowledge is very poor, however i did actually take my starter off and gave it a clean up on the old curvey. Surprisingly easy job as long as you get the washers back in the right sequence etc. If you have a Haynes manual and half a brain like me you can do it in half an hour or so.
Old 04-08-09, 01:40 PM   #6
Geodude
Geodude's Avatar
Originally Posted by Spanner Man View Post
Good afternoon all.
Cheers.
Thanks Mr Spanner man i will try ASAP
Mechanical knowledge hmm i made a lego house once.. Seriously though thanks Mr Spidey all advice greatly received. I do have the manual for which i guess i need another manual to understand the manual
Old 19-03-11, 03:42 PM   #7
Geodude
Geodude's Avatar
Started doing this again yesterday but it was like there was something stopping the starter from turning? Press starter button starter goes to turn maybe a 1/4 turn but wont like somthing is holding it back? leave for anything from 10 seconds to a minute or two try again and its back to normal? Hard to explain in written form so hope this is understandable.
Old 19-03-11, 06:41 PM   #8
Geodude
Geodude's Avatar
Read on net that starters can have a bad spot, could that be worth investigating? also forgot to mention that its intermittent if that helps.
Old 19-03-11, 07:35 PM   #9
Pull the bugger out and clean the comm up, see if there's any arc damage on the comm segments.
Old 20-03-11, 09:59 AM   #10
Geodude
Geodude's Avatar
Ok will clean comms but Haynes book of lies says use only crocus cloth and i cant find any so whats the equivalent? or do i just use wet and dry even though book says no
Starter Motor Grinch Stuff Wanted 0 02-04-08 10:24 PM
starter motor change gdharbourne SV Talk, Tuning & Tweaking 5 30-11-07 09:10 PM
Starter motor lynw Stuff Wanted 1 22-02-07 01:41 PM
Starter motor - curvey svrash Stuff Wanted 0 14-06-06 02:37 PM
Helen's starter motor BillyC SV Talk, Tuning & Tweaking 38 01-09-05 08:07 PM
