Old 04-08-09, 05:06 PM   #1
cF^
Default Fitting bagster tank bag
Where the hell do all these straps go?
Does the tank come off?!
From what it looks like, it seems that one strap at the front may feed to the buckle at the seat end and the strap at the seat end feeds to the buckle at the front, with clips clipping around the edge of the fuel tank. Does this sound correct? Want to make sure i've got it right before I start pulling my bike to peices trying to fit it! I thought you didn't have to remove the tank to fit these things...
Old 04-08-09, 05:39 PM   #2
MR UKI (1)
Default Re: Fitting bagster tank bag
You do need to lift the tank by undoing the 2 bolts near the headstock, then use the straps near seat to strap it to the frame and the headstock ones strap somewhere near the front. Can't remember exactly where I strapped mine, but the cover is such a snug fit it shouldn't move anywhere.
Old 04-08-09, 06:10 PM   #3
FG1
I didn't lift my tank.
The front straps go around the headstock.
The rear straps around the tank hinge.
The little clips sit under the lip of the tank.
Job done.
Old 04-08-09, 06:12 PM   #4
MR UKI (1)
Job done.
Yeah, but your special
Old 04-08-09, 06:25 PM   #5
Loz
Job done.
Ditto....
Old 04-08-09, 06:41 PM   #6
FG1
I'm not special. The school I went to was a special school though.
Old 04-08-09, 07:31 PM   #7
Rai86
Job done.
+1
Just make sure its nice and tight and you put the front straps properly round the head stock
Old 04-08-09, 08:42 PM   #8
cF^
Ty FG1, I'll have a play tomorrow and hopefully it'll be sorted. Your (orrible) red tank cover is now a brilliant shiny silver
There seems like there will be shedloads of spare strap hanging down if I use this method, shall I just chop em off?
Old 04-08-09, 09:09 PM   #9
FG1
There shouldn't be too much spare strapping. The small ones on the side of the tank will slide back between tank and frame.
Old 05-08-09, 06:07 AM   #10
Geoffrey
one strap for under the headstock and one strap for under the rear subframe, then the two rubber clips clip on to the bottom of the petrol tank. wait to do it when the sun is out, leave the cover laying in the sun so it heats up and it will be a little more pliable
black bagster tank bag Quiff Wichard Stuff Wanted 5 03-08-09 07:28 PM
Bagster Cover and Tank Bag Sally For Sale - SV's and SV related items 19 12-04-09 07:24 PM
Bagster Tank Cover. popeye SV Talk, Tuning & Tweaking 9 15-05-08 12:53 PM
Bagster Tank Bag danf1234 SV Talk, Tuning & Tweaking 11 24-03-07 07:22 AM
would a bagster tank cover/bag for a curvy tank fit a pointy muffles SV Talk, Tuning & Tweaking 15 19-05-06 04:31 PM
