Old 16-08-09, 09:23 PM   #1
Bikermike59
Default Things to watch for when buying an SV?
Hi,
in the process of buying a 2001 SV650s (curvy model)
And was wondering if there are any faults and things to look out for when buying one?
I know early suzukis (GS) has charging and alternator probs! anything else that is a common fault with them?
Thanks!
Old 16-08-09, 09:26 PM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Things to watch for when buying an SV?
No real "faults" as such. Try to find one with a good finish, check the heads on the major bolts cos they are made of cheese mainly and try if it has a fender extenda already on the front then even better.
thast all i can think of now.
Old 16-08-09, 10:01 PM   #3
from what i have read on here:
rectifier
rust
dodgy electrics
swingarm bearings
steering head bearings
seized rear callipers
camchain adjusters
Old 16-08-09, 10:02 PM   #4
hovis
do a search fella
Old 16-08-09, 10:05 PM   #5
arcdef
Oil leaks!
Old 16-08-09, 10:05 PM   #6
hovis
hang on...........
heres a start, just pick the ones that aply
http://forums.sv650.org/showthread.p...ghlight=buying
but i think this covers just about everything
http://forums.sv650.org/search.php?searchid=1006071
Old 16-08-09, 10:14 PM   #7
davepreston
rectifier hard to check when buying so honesty from seller is important
rust around rear sub frame is common but no dramas
dodgy electrics only when messed with and recifier as above
swingarm bearings most times a regrease is all it needs but alow for £30 if there is a problem
steering head bearings as above
seized rear callipers sv special ask when brakes were last seviced if at all allow £50 for time and effort to sort these out
camchain adjusters notoriusly prone to rust as are drive chain adjusters a proper dose of copper slip and a good strip and clean are easy fixs
batteries have a habit of dying on sv's £30-40 for new one
then just the usual look out for things on any bike eg chain and sprokets £100 tyres £180 brake pads £40 oil level and brake levels £25
hth
Old 16-08-09, 11:07 PM   #8
Bikermike59
Thanks for your help guys! :0)
Watch out, watch out, BigApe is about. Stig TOTALSV Ireland 14 04-08-06 04:28 AM
Buying a used SV, things to check? Saracen SV Talk, Tuning & Tweaking 6 13-11-05 07:11 PM
Insurance changing, things to watch out for Anonymous Bikes - Talk & Issues 11 18-02-05 10:48 PM
