Old 17-08-09, 07:48 PM   #1
Old Git
Old Git's Avatar
Default Curvy caliper service
Searched other threads, seen that they can be stripped & cleaned OK, read through the manual, but what should I have ready as a minimum.
Brakes are not giving any problems, but want to go through them before the bad weather starts.
So, what should I get ready incase b4 i strip;
1./ seal sets
2./ Red rubber grease
3./ brake cleaner
what else, should I get new bolts? pins? pads?
would hate to take em appart & not have essential kit.
any suggestions please chaps.......
Old Git is offline   Reply With Quote
Old 17-08-09, 08:26 PM   #2
Default Re: Curvy caliper service
Do you need it daily? If not I'd say strip it and see, wemoto will send you bits out next day if you need.
Parts for every eventuality are seal kits, pads, R clips, pistons.
Old 18-08-09, 01:03 AM   #3
Old Git
Old Git's Avatar
yep, basically everyday. gets used for work run during the week & blast at weekend unless it is getting fettled or washed.
Old 18-08-09, 07:42 AM   #4
captainsmelly
pins will probably be stuck
Rear caliper, for curvy captainsmelly Stuff Wanted 4 15-07-09 07:59 AM
curvy rear caliper and torsion arm trouty Stuff Wanted 0 09-05-09 01:21 PM
Front Caliper Piston Service + Fluid Refill branny SV Talk, Tuning & Tweaking 23 24-01-09 01:16 PM
Wanted - rear caliper for a curvy bad_hat_harry Stuff Wanted 0 20-11-06 08:13 AM
K3+ rear caliper on a <K3 curvy snoopy SV Talk, Tuning & Tweaking 9 30-03-05 06:49 PM
