Old 21-08-09, 08:11 AM   #1
slark01
Default Small crack in tyre.
I have a small crack in my tyre it's 1cm in length and 1/2 mm in width. Wondering if this is a problem that needs fixing or am I just worrying over nothing. Sorry about the large image
Ste.
Old 21-08-09, 08:17 AM   #2
speedplay
Default Re: Small crack in tyre.
Cant see it.
Needs a bigger image....
Old 21-08-09, 08:23 AM   #3
slark01
Better, smaller photo.
Ste.
Old 21-08-09, 08:28 AM   #4
speedplay
How deep is it?
If its just a surface cut I wouldnt bother with it.
Old 21-08-09, 08:32 AM   #5
MattCollins
That just looks like a small cut in the tread and nothing to worry about unless it has penetrated the casing.
Old 21-08-09, 08:50 AM   #6
slark01
Cheers guys!
It is only in the tread, so i'll just leave it be.
Ste.
Old 21-08-09, 01:34 PM   #7
AmigaNut
Just blame all the cr*ap on the road the councils refuse to sweep up.
Its a common problem and nothing to worry about.
Probably picked up a piece of glass and then lost it again.
It does not look serious.
Old 21-08-09, 01:42 PM   #8
trumpet
Use B-roads a lot had a few in my rear when i replaced it
Old 21-08-09, 04:32 PM   #9
Dangerous Dave
Looks harmless, I take it the tyre is holding its pressure?
Should a tyre crack after 4500 miles? svrich Bikes - Talk & Issues 23 26-11-08 09:40 PM
My crack has gone.... Girth Idle Banter 17 13-08-08 06:29 PM
can you crack this? Dave The Rave Idle Banter 9 11-03-08 03:56 PM
can you crack this? Dave The Rave Idle Banter 71 17-02-08 08:50 PM
Ladies Bike gear - Small or Extra Small! StreetHawk Stuff Wanted 8 07-12-07 06:18 PM
