Well folks I'm getting there with the parts for the GSXR front end.
I need gsxr radial caliper bolts and some braided lines. If anyone has either or knows where theres an offer on either give us the nod ![]() Cheers Nick |
You can reuse your SV brake lines
I have a brand new set of Hel lines (2-line kit, smoked cover and black fittings) - I ordered them too short for a GSXR/naked conversion, but they'll be a bit longer than stock. If you can live with that I'll part with them for £35 + shipping. They cost me £58 and have only been loosely test-fit w/o any fluid.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
#5 | |
Nick |
They fit a radial caliper & OEM radial master, but from memory they're a couple inches longer than stock. I can measure if you like but don't have the stock length to compare with (Hel might?). Otherwise they should just have a bit more slack than standard, which shouldn't be a problem if you route it with a bit of care.
Here they are test fit- hard to see in the pic, but they were a bit too snug with the higher bars: Don't want to pressure you though if you're not sure. I'll just chuck them on ebay otherwise. cheers, -Mike
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) Last edited by CheGuevara; 20-01-20 at 09:53 PM. |
#7 | |
My bars won't be so high therefore should fit mine. Can you meausre them and i'll measure mine? As long as there similar and they'll fit my master cylinder I'll have em. Cheers mate |
That's a GSXR radial master in the pic actually. The fittings on that end are at a slight angle (maybe 15deg?) from memory, but I'll verify that along with the measurements (later this eve I would expect).
Cheers, -Mike
#9 |
#10 |
Argh sorry - been kept busy. Will try and grab it in the AM -they're out in the garage which is like Fort Knox now that I've had 2 bikes stolen
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
Do braided brake lines wear out? | BigFootIsBlurry | SV Talk, Tuning & Tweaking | 1 | 20-05-09 06:38 PM |
Braided brake lines | Spokey | Stuff Wanted | 13 | 29-09-08 07:36 PM |
Which braided brake lines for SV650? | zunkus | SV Talk, Tuning & Tweaking | 19 | 28-03-08 12:20 PM |
braided brake lines | adey | Stuff Wanted | 2 | 22-11-05 09:16 PM |
