Old 27-08-09, 08:23 PM   #1
sv650nutter149
Default koso clocks
hi all have just had the koso rx2 clock installed on my gsxr srad but they only seem to be reving to 7k instead of 15k can anyone suggest y this may be?
cheers
ian
Old 27-08-09, 10:02 PM   #2
davepreston
Default Re: koso clocks
should be in the instructions about the amount of wire you wrao round the plug if its the same as my vapour
Old 27-08-09, 10:24 PM   #3
Probably a setting somewhere to tell whether it is set to 2 or 4 stroke mode or wasted spark or not.
Not sure which the SRAD uses, by the sound of it, it is set up for wasted spark system (like the SV, 1 spark per revolution) and actually uses traditional firing (1 spark per 2 revolutions).
Old 28-08-09, 05:24 AM   #4
arenalife
The KOSO's have quite a few settings for different firing systems usually, have you got the manual? They're on the net if you haven't.
Old 28-08-09, 01:53 PM   #5
Dangerous Dave
Correct
Old 29-08-09, 03:54 PM   #6
sv650nutter149
so out of the coil set up would it be 4 coils to 4 pistons ??? i have heard this is the case but clocks think other wise
Clocks or no Clocks Demonz SV Talk, Tuning & Tweaking 15 04-07-08 03:55 PM
help with clocks please stevep SV Talk, Tuning & Tweaking 2 06-05-08 10:30 PM
Fitting Koso Clocks instigator SV Talk, Tuning & Tweaking 20 08-05-07 12:39 PM
clocks dirtydog For Sale - SV's and SV related items 0 09-03-06 05:14 PM
New clocks svpilot SV Talk, Tuning & Tweaking 6 01-12-05 01:23 PM
