Old 03-09-09, 06:36 PM   #1
Neeja
Default Curvey tacho dead
Just finished putting in new pilot jets to replace my manky ones, also discovered that the front vacuum hose cap had got all mankey, so covered it while the engine was running. Revs shot up, so think I've found my main problem. Put a bit of tubing with a bolt in it over it, bike now idles fine and started from fairly cold with no choke.
Unfortunately, after bolting it all back together, the tacho is now gone. It was working earlier on, as I was using it to set the idle speed, but some time between putting the idle right, removing the carbs to make sure that the bolt/tube combo was secure and going nowhere, and putting it all back together, it's stopped working.
I know it runs off the front cylinder, so is there anything I might have dislodged to stop it from working?
Old 03-09-09, 07:16 PM   #2
Neeja
Default Re: Curvey tacho dead
After a bit of fiddling and testing, the front cylinder isn't firing. Joyous.
Old 04-09-09, 09:19 AM   #3
You've knocked connector for LT off the front coil. It is on left of frame right near engine breathers.
I have never made same mistake myself. Honest.
Old 04-09-09, 06:39 PM   #4
Neeja
I uhh, I would never make such an elementary mistake.
In fact, upon starting the bike today, it's running perfectly.
First time I've ever been able to start it in the summer with no choke and not have it die instantly. Few seconds of choke and it's happy as larry
Now to go see how it feels with a cleaned and adjusted clutch and carbs that work...
Dead curvey clocks.....again svrash SV Talk, Tuning & Tweaking 0 19-04-07 11:11 PM
Tacho not working Tris SV Talk, Tuning & Tweaking 6 13-05-06 05:18 PM
Bulb size for the tacho...curvey S svrash SV Talk, Tuning & Tweaking 1 08-04-06 11:34 AM
Rattle above 8k on tacho TSM SV Talk, Tuning & Tweaking 0 12-08-05 11:33 PM
Spinning Tacho Longshotmojo SV Talk, Tuning & Tweaking 4 19-06-05 05:02 PM
