Old 07-09-09, 09:01 AM   #1
hovis
Default cracked mobile screen
after beating binky in a game of darts, my drunken celibrations consisted of trying to life bitany spears, it all wnt a bit pete tong and we ended up on the floor
hence i have a smashed screen on my phone (PAYG) i can get it fixed for £40 or get a screen off ebay for £12
how easy is it too fit, will i need special tools. solder it etc?
its a nokia 6220 classic
Old 07-09-09, 09:14 AM   #2
Heed
Default Re: cracked mobile screen
You'll at least need a set of small torx screwdrivers but you can get them off eBay for £2 delivered. Fitting the screens isn't normally hard and it's normally just a connector rather than soldering. It will be very fiddly though.
Old 07-09-09, 09:21 AM   #3
Geoffrey
that is the lcd display, not the screen.
the screen is the clear protective piece of plastic, on my nokia it is attached to the rest of the front cover. if yours is the same you will need a small torx driver and possible a small flathead screw driver too. use google to find instructions on how to remove the fascia or cover.
cracked cylinder robbieracer SV Talk, Tuning & Tweaking 4 22-11-07 10:36 AM
Puig db screen cracked by itself Jussi SV Talk, Tuning & Tweaking 2 06-04-07 05:27 PM
Cracked can - bad fitting ? dotted SV Talk, Tuning & Tweaking 6 25-09-06 07:37 AM
cracked case auldyin SV Talk, Tuning & Tweaking 3 20-07-06 07:25 AM
Cracked clocks wtdafk SV Talk, Tuning & Tweaking 6 10-07-06 06:45 PM
