Old 15-09-09, 02:22 PM   #1
peddler
Thumbs up Renthal Bars-just fitted
Hi all, Im new to the forum and just got my 06 SV 650 last Saturday.
Didnt quite gel with the standard bars especially after sitting on one with Renthals fitted. They felt good.
So after reading all the many threads on the subject managed to pick up a set of Ultra Lows with brace for £5.50 on ebay.
They and the bar ends id ordered arrived today and a couple of hours later fitted with no problems, mainly due to the tips I read here.
The Ultra Lows fitted fine though I did trim 25mm off the bars to prevent any stretching of cables (jubillee clip was great as a guide for a nice straight cut)
I also opted to drill the holes for the locating pins. This was a doddle and well recommended. A bit of tape round the bars and then pressing the switch gear in place left a nice indent to mark for drilling. A 5mm hss new drill bit went through like it was soft wood.
A lot easier than I thought it would be, but as I said due to the tips from you guys....and the bars are spot on..
Thanks to anyone who gave the fitting ideas
Old 15-09-09, 04:12 PM   #2
appollo1
appollo1's Avatar
Default Re: Renthal Bars-just fitted
Hi Peddler
Can you put some pics up to show what it looks like now please?
i'm not old i'm experienced!!
http://www.german-shepherd-rescue-scotland.org.uk/ everyone deserves a second chance
RIP Appollo miss you and will always love you x x x x
appollo1 is offline   Reply With Quote
Old 15-09-09, 06:42 PM   #3
peddler
I,ll give it a go, bear with me..
Old 15-09-09, 07:02 PM   #4
peddler
Pics should be attached if iv done it right
Old 15-09-09, 07:08 PM   #5
wow
Nice looking bars
Old 15-09-09, 07:12 PM   #6
peddler
Cheers WOW, a bargin as well!!!
Old 16-09-09, 01:20 PM   #7
Domas
What is advantage of these bars over stock ones?
Old 16-09-09, 01:58 PM   #8
They don't bend like paper when you crash!
Old 16-09-09, 03:18 PM   #9
Warthog
Lower and wider usually, depending on the type you have chosen, which will give you quicker and easier steering but make you feel like a sail on a motorway
Old 16-09-09, 03:21 PM   #10
sunshine
there wider so have better stability great for new riders, if you want another easy way for that same result try bandit bars slightly wider and the holes are pre-drilled in the right places, also flea bay keep them cheap too.
Renthal Bars Speedy SV Talk, Tuning & Tweaking 5 14-06-09 09:18 PM
Renthal Bars sv_to_gsxr SV Talk, Tuning & Tweaking 7 19-06-08 09:08 AM
Renthal Bars - Which Ones? & Fitting? SV-net SV Talk, Tuning & Tweaking 19 10-03-08 12:11 AM
Renthal Bars 21QUEST For Sale - SV's and SV related items 1 06-04-06 09:10 AM
Renthal Bars for SV 650 Chris V SV Talk, Tuning & Tweaking 16 01-09-05 05:37 PM
