does anyone understand them?
i have cubase but they midid file sounds rubbish unless i pay a man £7.50 per track to record it for me. Id really like to undertsand what it is he does and what i need to record my own tracks from midi. I thought VST done this but apparntly not. Id prefer to ask people on here as other forums reagrding this come back with technical jargony speak and i prefer to keep things black and white any one know how this is done |
I'm not using cubase, but isn't a midi file just a sequence of notes that is played through a vst plugin - whether thats a synth or sample trigger or whatever. Shouldn't sound of anything on its own, so the vst must be set up wrong if its not playing properly.
Unless you did what I kept doing, recording midi sequences far off the end of the virtual keyboard. That doesn't work. Whats happening to your recordings? Last edited by captainsmelly; 16-09-09 at 05:52 PM. |
im not getting anything.....Im not even sure i have the correct set up. I can play midi files through windows media player and they sound rubbish. what do i need to make them sound good?
You basically need a good midi output sound card. I select on cubase in the "out" bit of midi tracks "Microsoft Wavetable GS Synth" or something like that, and the midi files play fine with the proper range of instruments. I am having troubles recording midi as audio in Cubase but that is a different problem if anyone fancies helping me with that!
#5 | |
can i fit this to a laptop? |
This is where I set it, does this help?
helps allot. im of to try it
#9 |
I midi through a sound module/keyboard. The midi files choose the instrument and the sound mod/GM keyboard has the sounds, which are then amplifed or recorded as I need. Palying midi through the pc just uses the basic pc sounds. Oh and I connect usb to midi convertor and input to a midi sound mod/keyboard
#10 |
Well yes, unless you have a decent sound card which I do. I think the issue is that Ross is using a laptop which might have very basic on-board sound.
Midi | sv_rory | Idle Banter | 5 | 03-07-09 11:05 AM |
uploading files? | arcdef | Idle Banter | 3 | 17-03-09 10:18 PM |
X Files | eviltwin | Idle Banter | 10 | 26-07-07 03:32 PM |
Rockford files | cuffy | Idle Banter | 9 | 21-04-06 12:46 AM |
SV End Can Sound Files | I'm_a_Newbie | SV Talk, Tuning & Tweaking | 7 | 14-04-06 10:37 PM |
