Hi
Bought an 03 SV650 a few weeks ago (private sale). It's been running well but just recently the gear changes have got clunky, occasionally gets stuck in 1st when trying to move into 2nd, and gearbox seems to be a lot noiser when going down through the gears. Should i be worried!? |
when was it serviced last?
have you checked the oil? |
check the oil.tighten lube the chain,had the same problem on my curvey,taught i bought a lemon,geting stuck between 1st and 2nd not going into neutral,not going into first etc all fixed by tightening the chain
It was serviced about 1500 miles ago, and the oil level seems fine.
clean chain with parrafin. dry with rag. lubricate with good chain lubricant. Adjust.
Then, whip off the front sprocket cover (if you havnt already) and clean the clutch worm drive. Slacken the cable right off and adjust the worm drive (undo the 10mm nut, screw the little bar in until it juuuust touches whatever it touches, then screw back out 1/4 of a turn, then holding it there, tighten the 10mm nut up). readjust cable slack. Clean and lubricate (with some oil, not WD40...) gear lever pivot. Hopefully, this should all do the trick ![]() |
Thanks for the advice, I'll give it a go this weekend (or somebody with a better idea of what they're doing will!)
Cheers |
Don't service your chain with engine running & in gear
![]() As said, chain is a good place to start though.
The gear box shaft can get gunged up, clean it and give it a spray with some sort of lube... No K-Y...
Gear change problem-can't get past 2nd gear | muzikill | SV Talk, Tuning & Tweaking | 8 | 14-03-10 10:10 PM |
Clunky gear changes | Holdup | Bikes - Talk & Issues | 3 | 02-04-09 01:04 PM |
Gear change feels more clunky than usual? | krhall | SV Talk, Tuning & Tweaking | 7 | 18-03-08 05:07 PM |
Gear change problem-can't get past 2nd gear | muzikill | SV Ecosse | 8 | 13-09-07 07:45 PM |
