Old 22-09-09, 05:01 PM   #1
EssexDave
Default VFR400 breather hose
Mine has snapped, is this going to be a problem? Eg should I stop riding it until fixed?
thanks
Dave
Old 22-09-09, 05:06 PM   #2
fastdruid
fastdruid's Avatar
Default Re: VFR400 breather hose
Which breather hose?
From memory there are about 5
Druid
Old 22-09-09, 05:08 PM   #3
EssexDave
The one out of the top of the tank.
Old 22-09-09, 05:10 PM   #4
fastdruid
fastdruid's Avatar
No and no, although you may want to be careful if there is a chance of water getting in.
Druid
Old 22-09-09, 05:11 PM   #5
EssexDave
So no rush to get it fixed? What does it do exactly?
Thanks again druid.
Old 22-09-09, 08:28 PM   #6
fastdruid
fastdruid's Avatar
It allows air to get into the tank to replace the petrol that has flowed into the carbs, the little thingy (technical term) that screws into the tank contains a one way valve that allows air in but no petrol out.
Most modern bikes (eg the SV) combine this function into the fuel cap.
Druid
bending breather hose lukemillar Bikes - Talk & Issues 2 17-08-09 09:16 PM
Need a breather? gettin2dizzy Bikes - Talk & Issues 3 21-04-09 10:09 PM
Petrol tank breather hose trick SV Talk, Tuning & Tweaking 5 10-09-05 11:55 PM
Honda VFR400 arc123 Bikes - Talk & Issues 12 20-04-05 11:24 AM
breather hose material northwind SV Talk, Tuning & Tweaking 3 27-10-04 11:26 PM
