Old 30-09-09, 03:59 PM   #1
svdemon
Default GSXR front end speedo
I'm going to fit the speedo to my front end (K3 GSXR) I have fitted aftermarket discs (10 bobbins) which means i can't do the old magnets in the holes trick.
I was planning to stick the magnets to the disc and need to make sure the speedo is going to be accurate. Anyone know if there is a set distance the magnets need to be fron the axle in order for it to be accurate? I could always mount them wherethey would go on standard discs providing they will fir there.
Any ideas gratefully appreciated!
speedo problem w/ GSXR front end catchsomesv650 SV Talk, Tuning & Tweaking 4 19-02-09 08:46 PM
Easy way to fix speedo with GSXR front northwind SV Talk, Tuning & Tweaking 40 04-12-08 01:35 PM
GSXR front end speedo work around Lozzo SV Talk, Tuning & Tweaking 32 13-05-08 05:32 PM
GSXR front end speedo conversion sensor svrash Stuff Wanted 11 26-01-08 11:52 PM
For those with GSXR Front ends & USA Speedo andyb SV Talk, Tuning & Tweaking 4 25-09-07 10:57 PM
