Old 06-10-09, 11:14 PM   #1
stuartgallafant
Default Cooling fans constantly on
Hi people, i've been on here a while now, but not had much to say! However, im hoping you might be able to help me out regardless?!
Im the proud owner of a Candy Grand Blue K4, with a few tasteful mods.
Just recently, everytime I switch the ignition on, the cooling fans come on straight away, regardless of the temperature, even if the bike has been sat for a couple of days.
Im just wondering if any of you have experienced the same problem and if so, what was the cause? If not, do you have any suggestions?
Im not afraid of getting my hands dirty, as im a BMW tech (cars!) but im learning more and more about bikes all the time. Its all just nuts n bolts really!!
My initial thoughts were a stuck relay or faulty temp sensor?
Any help would be greatly appreciated
Stu
Old 07-10-09, 12:17 AM   #2
xXBADGERXx
Default Re: Cooling fans constantly on
Sounds like a faulty Cooling fan Thermo-Switch to me .
Old 07-10-09, 03:53 AM   #3
2hys
yes posable fan switch is stuck on sits on the bach of the rad on the righthand side ive got a brand new one still in box if your intrested 20 quid posted!
welcome to the the org
Old 07-10-09, 06:37 AM   #4
Spanner Man
Good morning.
A dodgy fan switch sounds like the place to start. Un-plug it when the engine's cold & see if you have continuity across the terminals. If you have then it's probably had it.
Cheers.
Spanner Man
Old 07-10-09, 08:00 AM   #5
stuartgallafant
Thanks for your help chaps, i'll have a play with it while at work today and let you all know.
2hys, if this is the cause, then i'd be interested in taking the switch off your hands.
Thanks again, i'll reply results soon
Old 07-10-09, 10:41 PM   #6
stuartgallafant
Hi guys, just to report...
I took the connector off the rad. temp. switch earlier at work and found that there was a little bit of water that had got into the housing, bridging the contacts and keeping the fan on!
I stripped the connector down completely and made sure there was nothing rotten or corroded, sprayed her up with some WD40 n put it all back together and it works great now.
Thanks for the help,
Stu
Old 07-10-09, 10:48 PM   #7
xXBADGERXx
Glad to be of service
Old 12-10-09, 03:50 PM   #8
stuartgallafant
Hi guys, fault has returned, i done resistance check across the sensor/switch when cold and it had a closed circuit, so i reckon it out!!
2hys/rhys, i have pm'd you mate
When riding the bike hard... constantly... SVTristan SV Talk, Tuning & Tweaking 0 04-05-09 02:36 PM
SV650 constantly blowing "Signal" fuse loply SV Talk, Tuning & Tweaking 5 01-11-07 07:44 AM
sv650 k1 cooling fan bugsy46 SV Talk, Tuning & Tweaking 3 21-06-07 09:00 PM
Too much cooling help Bonart SV Talk, Tuning & Tweaking 7 29-12-05 09:15 PM
Cooling Fan Banus SV Talk, Tuning & Tweaking 7 10-06-05 09:05 PM
