Old 14-10-09, 01:31 PM   #1
skyline
Default Silly question from me on rear brake pedal
Hey all
A quick dumb question from me but I'm trying to raise the height of the rear brake pedal on my curvy SV
So, undo the locknut at the bottom of the thread connecting to the lever, and adjust the nut at the top of the thread to move the pedal.
However by the top nut is the rubber cover sealing the master cyclinder and every time I move the nut the cover twists and springs the nut back to the original position when the nut is released.
I can wind the locknut tight again with the pedal in position but the cover is twisted which can't be good for the seal.
Any one know how to adjust the pedal and stop the cover twisting?
Sorry for the dumb question
Old 14-10-09, 03:20 PM   #2
NedSVS
Default Re: Silly question from me on rear brake pedal
You need to try and stop the rubber bit twisting by holding it with your fingers whilst you turn the part that goes into the master cylinder (very fiddly, I know).
Old 14-10-09, 04:35 PM   #3
davepreston
i dont mean to sound funny but do you think its a good idea, the last thing you need is some inadvertant rear braking while cornering . just a thought
Old 14-10-09, 05:25 PM   #4
The rod isn't connected to the piston, (thus seals), it just pushes against it, so turning the rod won't damage the seals.
To adjust if the rubber gaiter is stuck on the rod, remove the lever clevis and turn the trunnion in the appropriate direction.
Old 14-10-09, 05:32 PM   #5
Spanner Man
Good evening all.
Try squirting a little silicone lube or similar, (MATRON) under the edge of the rubber boot where it sits around the adjuster.
Cheers.
Spanner Man
Old 14-10-09, 07:34 PM   #6
skyline
Great stuff, I'll give them ideas a shot. Cheers all!
I won't be raising the lever a huge amount but hopefully this'll mean I won't need to do gymnastic ankle movements anymore to work the brake lol!
anyone got a Rear Brake Pedal tonyk Thames Valley 7 06-09-09 06:48 AM
99-02 rear brake pedal Marcus Stuff Wanted 17 14-04-09 07:27 PM
rear brake pedal? seano Stuff Wanted 0 12-04-07 07:29 PM
Rear Brake Pedal 01 sv650s Stuff Wanted 0 29-03-07 07:59 PM
i've done something a bit silly to my rear brake muffles SV Talk, Tuning & Tweaking 11 31-07-06 08:14 PM
