Old 17-10-09, 03:59 AM   #1
Swin
Swin's Avatar
Default Electrical fault - indicators permanently on
I have a problem with my K4 pointy. I turn the ignition key, can hear the FI coming up, and the bike will start fine but on the dash I have both indicator warning lights solidly on and the high beam warning is on.
When I check the lights, the indicators are on all round and the headlamp is off. I had this before, and assumed it was an alarm condition as my alarm has been troublesome lately but Acumen tell me that it's nothing to do with their alarm as it wouldn't be wired to touch the headlamp, it only affects the fuel pump and ignition apparently, both of which are fine!
Grateful if anyone has an idea of anything I can try before I take it to my garage please!
Swin is offline   Reply With Quote
Old 17-10-09, 06:44 AM   #2
Spanner Man
Default Re: Electrical fault - indicators permanently on
Good morning.
It sounds like an earthing issue, or maybe water or corrosion on the wiring connecter that goes into the instrument panel. Get the connectors apart & give them a good clean with contact cleaner preferably, & see what happens. It could also be a similar problem with the flasher relay, give the connector similar treatment.
Cheers.
Spanner Man
Old 17-10-09, 08:10 AM   #3
Swin
Swin's Avatar
Thanks very much, I'll have a look at the bits you mention
Old 17-10-09, 03:50 PM   #4
sunshine
spray the inside of the switches with WD-40 always does the job for me. if that or above doesnt work start checking the wiring loom
Old 20-10-09, 01:37 PM   #5
Swin
Swin's Avatar
Originally Posted by Spanner Man View Post
Good morning.
It sounds like an earthing issue, or maybe water or corrosion on the wiring connecter that go into the instrument panel.
Cheers.
Bingo - you got it in one - the connector that feeds the indicators was melting - it appears to be an earth point for basically the front end!
Old 20-10-09, 01:58 PM   #6
Dave20046
Dave20046's Avatar
Is that the big block connector under the tank in front of the air box?
Old 20-10-09, 07:35 PM   #7
Baph
There's two such connectors. One is in front of the airbox, the other is on the very front of the nose cone, under the plastic behind the base of the screen.
I know, as the beggar behind the screen shorted on mine, and decided it wanted to melt itself. Easy diagnosis though, put your hand on the base of the screen, is it warm?
Old 20-10-09, 07:37 PM   #8
Dave20046
Dave20046's Avatar
ahh that sucks, better check that one for corrosion & spray next time I'm in the region.
ta
Old 20-10-09, 11:45 PM   #9
Spanner Man
Good morning all.
Twas a pleasure! That's what I'm here for.
Cheers.
Spanner Man
Old 21-10-09, 04:47 AM   #10
Swin
Swin's Avatar
It was the one under the front of the fairing as Baph mentioned
Unknown electrical fault? Alex_Chambers SV Talk, Tuning & Tweaking 3 23-06-09 06:08 PM
Intermittent electrical fault. warrenhewitt10 SV Talk, Tuning & Tweaking 0 30-05-09 11:27 PM
electrical fault DANINPLYMOUTH SV Talk, Tuning & Tweaking 2 18-09-08 02:19 PM
Electrical fault, help much appreciated! samwilko SV Talk, Tuning & Tweaking 3 24-08-08 12:31 PM
Possible electrical fault drag Bikes - Talk & Issues 14 07-05-08 09:31 PM
