Old 17-10-09, 12:38 PM   #1
Gene genie
Default front discs.
i've recently only noticed that my o/s front disc gets considerably hotter than my n/s disc. thinking there might be an issue, needed a proper clean anyway, i took both calipers off, dismantled them and re-fitted them. they feel great but still the n/s is cooler than the other.
is this common??
Old 17-10-09, 02:28 PM   #2
Dave20046
Dave20046's Avatar
Default Re: front discs.
Check the disc isn't warped.. When you took them apart did you check the movement of the pistons?
Old 17-10-09, 02:52 PM   #3
Gene genie
pistons moved freely and there no abnormal juddering when braking that might suggests warping, will check that though. cheers dave.
Old 17-10-09, 03:17 PM   #4
Dave20046
Dave20046's Avatar
Aye, I suspect you'd notice if it was warped. Those were the only things I could think of; i.e funny shaped disk rubbing or caliper dragging.
When you say you took it apart do you mean you took the pistons out? So the system's been bled up and seals checked?
Old 17-10-09, 03:50 PM   #5
Biker Biggles
Biker Biggles's Avatar
I take it its an SV?If so they are sliding calipers so one half of the caliper moves in and out as the brake goes on and off.Check that the one that gets hot still slides,as if it doesnt the brake will bind.
Old 17-10-09, 07:12 PM   #6
Gene genie
pistons out and bled dave.
good point biker biggles. if the piston ain't returning what would be the remedy?
Old 17-10-09, 07:27 PM   #7
Clean the shoite out of the bore that the rubber slider sits in. These rot inside and pinch the rubber onto the sliding pin.
Old 18-10-09, 06:13 AM   #8
Gene genie
thanks chris. did clean it out but i probably could've done a better job had i realised the importance.
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
front discs thewasp600 Stuff Wanted 1 08-04-08 09:05 AM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
Brake Discs for GSXR front end conversion on SV 320mm discs Ter For Sale - SV's and SV related items 0 22-09-06 04:50 PM
Front discs jonacol SV Talk, Tuning & Tweaking 7 10-07-05 08:39 AM
