Old 17-10-09, 07:20 PM   #1
Default Chain and sprockets
My chain has no stiff links, it's on 25k.
But, it's knocking a bit at low speed. I think because the teeth on the rear sprocket are a bit hooked.
I've got another C+S kit here, so do I sling that on, or just change the rear sprocket and hope to get another 5-10k out of it?
P.s it's 3 teeth up on the back, so chain isn't under that much load in use. Most of wear is me being hamfisted and forgetting to fill scottoiler.
Old 17-10-09, 07:37 PM   #2
Spikenipple
Spikenipple's Avatar
Default Re: Chain and sprockets
Really the whole lot should be replaced, but as long as you keep an eye on the condition of the chain I imagine it'll be fine.
+3 teeth on the back? What does it redline at in 6th? 80mph?
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 17-10-09, 09:57 PM   #3
Mr Speirs
Mr Speirs's Avatar
Normally I would say they need to be replaced together but to be fair YC you know what you are doing.
Old 17-10-09, 10:16 PM   #4
140 indicated on the limiter, but I've heard you need to grab someones slipstream to hit the limiter in top.
Old 18-10-09, 08:39 AM   #5
thefallenangel
how much is a rear sprocket? If it's only a tenner then yes as it saves the hassle of replacing the lot but look for any wear in the rollers on the chain too. Also before you do it check the front sprocket is clean, blah blah.
Man i feel like i'm teaching granny to suck eggs.
Old 18-10-09, 10:23 AM   #6
A rear sprocket is £20. Full drive kit was 100 or so.
Old 18-10-09, 11:51 AM   #7
xXBADGERXx
From my experience I have learnt that once they start doing this they are on their way out , remember mine at the GMII ? . It sounded terrible , I had 27k out of it before forgetting to fill the Scottoiler one month . I knew it needed doing before I went there , I had to slather it with chain lube at every other stop even with a Scottoiler on and filled up . On the way home it got progressively worse and was "Chunking" at 85 mph . I got the bike home by the skin of my teeth and replaced the lot within the week . Funnily enough my chain was fine and the same with the rear sprock ... it was the front that was hooked ? . Maybe due to carrying lots of luggage and being 2 up a lot this year ? . I felt like replacing just the front but as an engineer I have replaced many parts of conveyors including chain driven ones and have learnt from the past that it is folly to do so . It`s just a bodge to get a handful of extra miles out of it . If I was touring the world and needed to do a few k to get home then yes .... from an economy point of view ..... change the lot over as your new sprocket may not wear to the old chain , you may make the chain wear to the new sprocket if it has lost the ability to stave off any wear .
I have seen sprockets in industrial situations that may have been slightly harder than the chain they are mated to , the chain has lost any hardness due to wear , almost as if the surface hardness has been worn through and it`s down to the softer material underneath . This is on something very industrial with the possibility of many millions of revolutions ........ but stuff like that tends to stick in your mind . Now stop faffing about and replace the lot young man
Old 18-10-09, 12:36 PM   #8
YC, I've got a chain and sprockets from my SVs which has only done about 7.5k. It's just sitting in the garage. Think its ok too, I just replaced it with a bling gold one, which you won't like
The chain is unsplit as I removed the swingarm last winter
Just pay me the postage.
let me know by PM
Old 18-10-09, 12:38 PM   #9
xXBADGERXx
There ya go , Bargain , matching set.......ish for the price of a packet of ciggies and a Beer
Old 18-10-09, 12:42 PM   #10
I've already got a new set here maviczap, I appreciate the offer but I need to do something today (will be doing 1000 miles this week with no time to be working on bike).
Cheers for the offer but better to hang onto them for someone else who may need them more than I.
That said, don't chuck them out, they can sit in my garage in case anyone needs them if you want rid.
New chain and Sprockets. ThEGr33k Bikes - Talk & Issues 19 21-08-08 11:15 AM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
New chain and sprockets CDM SV Talk, Tuning & Tweaking 20 05-07-07 11:25 AM
Best Chain/Sprockets for SV '02? Joe rocket SV Talk, Tuning & Tweaking 4 01-03-05 08:49 PM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
