Old 22-10-09, 02:44 PM   #1
Nobbylad
Nobbylad's Avatar
Default What ARE you doing to your SV this weekend?
Me - fitting Valter Moto rearsets and measuring up for fitting my Gixer thou shock. Will top up the scottoiler, clean and polish the bike and generally faff about with it, much to the disgust of Nobbylass.
What are your plans?
Old 22-10-09, 02:47 PM   #2
mikelcfc
Default Re: What ARE you doing to your SV this weekend?
find out whats causing my clocks to go crazy, give it a good clean, fitting high level link pipe,, possible having the rear subframe off and respraying it,, not much :
Old 22-10-09, 03:01 PM   #3
Triton
Fitting Tailtidy, contacting SUZUKI UK for a CoC and generally getting buried in paperwork to re-reg the bike
Old 22-10-09, 03:28 PM   #4
Taipan
Taipan's Avatar
Checking out which caliper is starting to bind and why? Was going to attempt to get the fuel bowls off and check float heights and for sticky float etc as I have a slight weep from one overflow. But i'll robably wait for carb heater wiring to arrive and do it all the following weekend, especiually as teh fuel bowl screws are mashed up! I'll certainly give it a wash and maybe polish up the front downpipe as it looks manky. Bet I dont bother though.
Old 22-10-09, 03:30 PM   #5
sv-robo
Nothing.........i don't own one anymore
Old 22-10-09, 03:32 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
Might get round to fitting some front indies to it this weekend, only been meaning to do it for the past 3 weeks
2011 Speed Triple 1050
Old 22-10-09, 03:40 PM   #7
Old Git
Old Git's Avatar
Strip, clean & be-build the front calipers + new pads ready for the sheite weather that we will soon be having.
If it goes, it ort to be able to stop as well when required.
Old Git is offline   Reply With Quote
Old 22-10-09, 03:47 PM   #8
Figure out why the front ends wibbling a little on the brakes. Maybe make a start on an improved top yoke.
Might manage to get over to hindles house and fit his GSXR front end too.
Old 22-10-09, 05:42 PM   #9
Alpinestarhero
Clean and re-lubricate the chain.
Check tyre pressures.
Old 22-10-09, 05:44 PM   #10
Gene genie
don't know what i'll do, if anything, this weekend but the list is endless.
1. new rubber f+r.
2. chain crippled. needs replacing.
3. # plate light stuffed again.
4. valve clearances need checking, bit too big a job for me though.
5. the knock on the headstock is developing into more than just a knock.
6. front calipers off and cleaned, again.
What did you do to your SV at the weekend? Taipan SV Talk, Tuning & Tweaking 68 26-11-09 12:51 PM
The watcha doin at the weekend thread *Sponsred by what ever happened to the watcha doing at the weekend thread* Holdup Idle Banter 40 03-10-09 06:51 AM
This Weekend GMS Pennine Massive 7 08-09-07 10:36 PM
This weekend? Mervin The Essex Lounge 2 19-08-05 09:12 AM
