Old 26-10-09, 07:52 PM   #1
metalmonkey
Default Front brakes, brake pads.
As above I was riding the bike this afternoon, my brakes just didn't feel right.
When I pull on the front brake, it comes back further to the handle bar than it ever has. The feeling and feed back is different as well.
The brakes feel spongy, not as sharp as they did and for what of a better sluggish. I'm not feeling the confidence I did before.
On the outside of the resesvior that sits on top of the brake system, there was a bit a resdiue as well, to me this equals bad. Is it?
I had a look at the front pads, I would they are about 1-2mm for wear bar indicators from sight, my rear one is almost out. Would this affect the opertaion of the brakes?
So I do need new pads, this is a road bike so whats best use for road? As well as changing pads, is there anything I need to do with them to ensure they work correctly?
Thanks.
Old 26-10-09, 08:09 PM   #2
Holdup
Default Re: Front brakes, brake pads.
Check the resesvior, first that sounds a bit dodgey.
Maybe worth a fluid change, doubt you would need to do your seals as bike is only 3 yrs old how many miles you done?
Also cable tie your brake lever back over night, worked for me and many others on the forum and is probably the most simplest and effective way of sorting out the lever problem
Old 26-10-09, 08:14 PM   #3
metalmonkey
My bike is a K6, on an 07 plate I bought it from new. It has done 15 100 miles.
Old 26-10-09, 08:17 PM   #4
Dave20046
Dave20046's Avatar
I'd service the calipers when you swap the brake pads makes a world of difference.
I'd first bleed up your brakes see if it makes a difference, then try the cabletie/lever thing and see what affect it has .
Old 26-10-09, 09:14 PM   #5
metalmonkey
How do you service the calipers?
Old 26-10-09, 09:18 PM   #6
Holdup
http://forum.svrider.com/showthread....hlight=caliper
I used that guide, just ignored the other 4 ppistons etc and splitting the caliper
Old 26-10-09, 09:26 PM   #7
Dave20046
Dave20046's Avatar
I followed the logical advice I got from yorkiechris (IIRC) on here and disregarded the bit about soaking the seals etc. in brake fluid, I gave them a coating of rubber grease. They're not the same as sv calipers you'll also want to clean the **** out of the two shaft bits that the caliper moves on (that's bolted to the forks)
Old 26-10-09, 09:31 PM   #8
Dave20046
Dave20046's Avatar
As per holdups link & the above you'll need brakefluid, coppergrease, rubbergrease, brake cleaner, other cleaning equipment (toothbrush, rag etc)
I said to do the other stuff first though as I reckon it'd give you an indication as to whether you require seals or not.
Old 26-10-09, 09:31 PM   #9
Holdup
When you cleaned the caliper sliders did you clean the grease off then regrease them? what with i didnt bother, one one moving freely any way but the other and seized.
Old 26-10-09, 09:34 PM   #10
Dave20046
Dave20046's Avatar
I cleaned all the ****e & old grease out of them and regreased them, also gave the rubbers a coating of rubber grease in the hope it'd preserve them, stop them cracking -perishing etc.
Front Brake Pads. Biker Biggles Stuff Wanted 0 26-10-07 04:52 PM
Which front brake pads? thor Bikes - Talk & Issues 10 11-09-07 10:55 AM
Front brake pads advice danf1234 SV Talk, Tuning & Tweaking 10 04-07-07 05:06 PM
Front Brake Pads Knocking andyb SV Talk, Tuning & Tweaking 14 06-02-07 01:21 PM
Front Brake Pads for SV650 21QUEST For Sale - SV's and SV related items 0 18-12-05 05:46 PM
