Old 28-10-09, 11:32 AM   #1
SUPERSTARDJ01
Default Copper grease?
Hi,
Is copper grease ok to use bearings in the bottom yoke?
Old 28-10-09, 11:34 AM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: Copper grease?
Copper grease is for high temperature applications, probably better to use normal Lithium Grease if you have it?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 28-10-09, 11:39 AM   #3
SUPERSTARDJ01
Will they both do the same job?
Old 28-10-09, 11:43 AM   #4
the_lone_wolf
Captain Awesome
Possibly, copper grease is intended as an anti-seize though
Any auto shop will stock Lithium Grease in a big tub, go get the right stuff
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 28-10-09, 11:49 AM   #5
Richie
fantabulas
Richie's Avatar
copper greese will distroy your bearings as your bearing also have copper in them.
copper greese is not a lubricant, it's an anti seize compound and will self sacrifice itself when two allos are together, as in Alloy from the frame and steel from the race of the bearings and rollers.
get some proper grease.
I'd not use it for bearings.
I'd only use copper grease on the back of brake pads to stop brake disc dust squeel, on axels threads or exhaust bolt dowles.
hth's
My Flickr photos
Old 28-10-09, 11:53 AM   #6
Sosha
I wouldn't use copper grease on a bearing.
Struggling to think why though.
Possibly because it's an anti seize sort of thing rather than a lubricant.
Edit: Woah - too slow!
Old 28-10-09, 12:45 PM   #7
Dicky Ticker
Whats all this about lubrication--------I thought that was the £20 note you kept with your driving license
No don't use it for bearings----a common misapprehension
Old 28-10-09, 01:14 PM   #8
sz1
copper grease is a anti seize and should not be used on parts that move it acts like a grinding paste because of whats in it . use lithium grease or equivalent.
Old 28-10-09, 01:27 PM   #9
JamesMio
like this would be the best bet, £1.67 per cartridge, I've got some from work and it's good stuff.
"That **** on the push-bike."
Creatomatic
Old 28-10-09, 02:32 PM   #10
Hooligan
Copper grease is an abbrasive, 2 metal surfaces rubbing together will wear away with copper slip, rather than have no friction of normal grease. Hope this helps. If you get copper slip on your finger and rub it you can feel the abbrasiveness, lithium or moly grease is slippy, hence no friction
Grease - all you could ever want to know ? Spokey SV Talk, Tuning & Tweaking 9 22-10-08 08:01 PM
Copper grease; from where? butterick99 SV Talk, Tuning & Tweaking 12 22-05-08 09:45 PM
Grease pmapp Bikes - Talk & Issues 18 08-03-08 12:50 PM
grease latts650s SV Talk, Tuning & Tweaking 2 24-02-06 07:20 PM
Grease me up! markfc SV Talk, Tuning & Tweaking 9 07-03-05 07:10 PM
