Old 31-10-09, 03:53 PM   #1
pce13
Default M.O.T. Advice
Hi all
I just bought a 2000 X Reg SV650S which has been fitted with a carbon look hugger, its a little loose and shows signs of wears against the rear tyre, it moves a little and wondering would this fail the M.O.T.
ThankYou
Paul
Old 31-10-09, 04:15 PM   #2
Speedy
Default Re: M.O.T. Advice
Quite possibly this would fail, I test cars, so a bit different, but if a road wheel fouls any part of the car, unless it's designed to, it qualifies as a reason for rejection.
Best advice is to secure the hugger. If it has marked the tyre, should be ok as long as the tyres carcass/cords are not exposed where it was rubbing.
Old 31-10-09, 04:34 PM   #3
pce13
Thanks Speedy
i thought it might, it just feels loose and has rubbed the tyre but no visible damaged to tyre, just worn the edges of the hugger,
i tried to undo the little allen bolts securing the hugger but they where solid so i think one of the brackets has broken causing it to be loose
Old 31-10-09, 04:37 PM   #4
7755matt
Yup, fowling will fail. Try cable ties round the mounts
Advice on financial advice wyrdness Idle Banter 9 04-12-08 12:38 PM
advice for the new boy =] BBadger Idle Banter 16 23-06-08 03:33 PM
Advice ejtrent SV Talk, Tuning & Tweaking 3 03-07-07 09:52 AM
dog advice kitkat Idle Banter 22 22-06-07 09:17 PM
Advice on a GPZ please.... lynw Bikes - Talk & Issues 2 21-04-05 11:34 PM
