01-11-09, 06:14 PM | #1 |
Battery replacement - Gel or sealed type ?
I need to replace the original battery on my curvey (8 years and 35000 miles is quite good though!). My question is, does it have to be a gel type or fully sealed, as the battery is mounted at an angle?
02-11-09, 10:04 PM | #2 |
Re: Battery replacement - Gel or sealed type ?
The original isn't a gel battery - it's a normal lead acid battery, only sealed. Unless you've got it near flat a sealed battery will be fine.
02-11-09, 10:39 PM | #3 |
Thanks Sid
Battery charger - which type? | branny | SV Talk, Tuning & Tweaking | 4 | 29-12-08 04:08 PM |
Justi fitted a standard exhaust. Pipe sealed with silicone. How long before I start motor? | monkey | Bikes - Talk & Issues | 14 | 27-08-08 05:25 PM |
Gel V Sealed Lead Acid Batteries: | MrMessy | SV Talk, Tuning & Tweaking | 3 | 06-12-07 09:47 PM |
Brand New sealed Haynes manual 99-02 | lukemillar | For Sale - SV's and SV related items | 0 | 01-06-06 09:03 AM |
new can - signed, sealed & delivered | pegasus | The Essex Lounge | 15 | 20-07-05 07:05 PM |
