Old 10-11-09, 12:19 PM   #1
Default bleeding a hydraulic clutch
Anyone know how to bleed a hydraulic clutch on a Hayabusa? my mates clutch is draggin and he's got alot of play in the clutch lever but i cant see where to bleed it from?
Old 10-11-09, 12:23 PM   #2
philbut
Default Re: bleeding a hydraulic clutch
Usually at the slave cylinder (or it is on all the bikes I've had). Can you follow the line down from the lever to where it enters the engine. I bet you there will be a bleed nipple tucked away somewhere.
Old 10-11-09, 12:27 PM   #3
pookie
pookie's Avatar
Hi Kwak its sounds like the same position as the one on the sv1000 on the left side. Black with a nipple over on.
This sounds like the same problem http://www.motorcyclenews.com/MCN/Pr...utch-slipping/
Old 10-11-09, 12:38 PM   #4
humm sounds like that might be the problem, the bikes at my mates house but i will check this out next time i go to sort it for him.
when you try to ride the bike its like putting the bike ingear with virtualy no clutch and the bikes pulling already with the clutch in when it should be stationary?
he had the bike stolen but was recovered and all this has happened because the bikes stood while we've fixed it back up, the clutch isnt nacked because the theifs never even got the bike started.
Old 10-11-09, 12:43 PM   #5
philbut
Could be sticking clutch plates. My ZX7R does it when its been sat for a bit. Just give it some stick when you put it in gear the first time so it don't stall. It should free up after a while. new clutch plates maybe a better solution but I am cheap
Old 10-11-09, 12:44 PM   #6
kk will check that too, cheers peeps
Old 10-11-09, 01:19 PM   #7
Rocket
Kwak, when the bike was nicked it might have ended up on its side. Operating the clutch in that position can introduce air into the line as the master cylinder on the bars will not have fluid covering its take off point. Sounds like bleeding at the slave cylinder on the engine will cure it.
Old 10-11-09, 01:28 PM   #8
thanks rocket.
Old 10-11-09, 03:44 PM   #9
Alpinestarhero
When was the last time the oil was changed? When my bike sat unused for 8 weeks, I had problems with gear changes etc which was only cured until after the oil was changed.
In any case, bleed new fluid through i guess
Old 12-11-09, 09:18 PM   #10
fastdruid
fastdruid's Avatar
As said the bleed point is on the slave cylinder, once you get mostly fluid in the line there is no need to bleed them in the same way you to the brakes as the far greater fluid movement does it for you.
If it hasn't been used for a while it could have rusted the push rod (I'm assuming its similar to the SV but with a hydraulic slave) and its returning too far.
I also found with the VFR though that the fluid got well manky (faster than brake fluid) and a change of fluid made a massive difference.
Druid
Hydraulic clutch conversion? kawadave SV Talk, Tuning & Tweaking 32 25-02-10 07:39 AM
Hydraulic clutch - advantages? Ed Bikes - Talk & Issues 46 01-09-08 01:02 PM
bleeding clutch! jimmy__riddle Bikes - Talk & Issues 4 24-07-08 08:11 AM
Hydraulic clutch mod Damoulianos Marios SV Talk, Tuning & Tweaking 22 21-06-07 12:49 PM
hydraulic clutch SV-Sexy-virgin? SV Talk, Tuning & Tweaking 7 21-02-05 11:45 AM
