Old 11-11-09, 06:15 PM   #1
stuballs
Default PVC tube for sorting front preload
having removed my emulators (requiring cutting the stock spacer) I now need to sort out the preload. Is PVC tube ok for this? Assume there would be no issues with strength? Anyone know what size I'd need off the top of their heads?
cheers
Old 11-11-09, 06:27 PM   #2
DavieSV
DavieSV's Avatar
Default Re: PVC tube for sorting front preload
Am I right in thinking that you are removing the emulators for good?
and if so, were the damper rods not drilled out to allow the emulators to work correctly?
DavieSV is offline   Reply With Quote
Old 11-11-09, 07:32 PM   #3
phi-dan
phi-dan's Avatar
I've seen a few threads on this on other sites/blogs, and it would appear that so long as it is schedule 40 it ought to be okay. I've got some 32mm waste pipe waiting to be cutdown to length (when it stops raining) id:32mm, od:36mm which I'm hoping will do the job.
Please feel free to tell me I'm wrong - it'll save me finding out the painful way!
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 11-11-09, 10:02 PM   #4
RedMacgregor
I've not long fitted some Ricor Intiminators (similar to emulators). I needed to shorten my stock spacers but just in case I wanted to revert to stock suspension I decided to go the plastic pipe route and make some new spacers. I purchased some really solid rigid 32mm grey PVC pipe from my local koi carp/aquarist supplier. It's pressure pipe, very tough, easy to cut and not affected by fork oil.
I paid a couple of quid for half a metre of the stuff - ended up using a couple of inches!! Should be easy to find locally with Google.
Old 11-11-09, 11:22 PM   #5
AZ Pete
if your's is equiped with preload adjustment screws, you may likely find that the plastic tubing, being thicker, interferes with the spring clip that is on the bottom of the preload adjuster (inside the fork tube cap).
Old 12-11-09, 12:34 PM   #6
RedMacgregor
AZ Pete is dead right - I had to fit some slightly smaller clips as the original ones push the spacers out of line slightly.
Front Preload ? hindle8907 SV Talk, Tuning & Tweaking 18 31-07-09 01:42 PM
Front preload query simesb SV Talk, Tuning & Tweaking 12 03-07-08 04:42 PM
Help sorting GSXR front end search JuicyGuzzi SV Talk, Tuning & Tweaking 15 23-08-07 01:11 AM
Front Spring Preload big twin grin SV Talk, Tuning & Tweaking 1 13-04-06 05:44 PM
Front preload caps on pre 02 model Fuzz SV Talk, Tuning & Tweaking 14 08-09-05 06:43 PM
