Track Days Post up here about trackdays
Old 21-11-09, 11:02 PM   #1
mikelcfc
Default crashes exiting edwinas??
was it just today or is it a common thing??
90% of all crashes today ( must have been at least 9 there today) were on the exit of edwinas... is it particularly slippy in the wet or all the time?? or just coincidence?? there seems to be a lot of scuffs in the track there too
Old 22-11-09, 09:42 AM   #2
G
Default Re: crashes exiting edwinas??
Common place.
If you take the wrong line then the corner tightens up, a lot of people break and go down, or lean further and lowside.
Its a really funny corner with a funny line. You have to go slow in to make sure you stay over to the left of the track after you have first turned in to make sure you get a good line when turning right exiting edwinas.
If you go fast and take the natural line for a left hander then you end up on the apex of the right hand exit far to early, where there is less grip and there are marbles, and you will probably be carrying to much speed into the corner anyway taking that line.
Old 22-11-09, 10:54 AM   #3
mr.anderson
mr.anderson's Avatar
That is an odd corner. I found it really easy to go far too fast coming out of it. Managed to keep it right way up though.
mr.anderson is offline   Reply With Quote
Old 22-11-09, 06:53 PM   #4
chris8886
chris8886's Avatar
i disagree. it's a horrible corner! lol. and no i didn't crash exiting it (i just didbn't really like it).
AR08 to AR13-QUALITY!
Old 22-11-09, 07:54 PM   #5
mister c
mister c's Avatar
I'll let you know next month
Mmy son's 1st crash was at Edwinas, he highsided coming out after getting on the power too early.
Old 22-11-09, 11:53 PM   #6
mr.anderson
Yep, you crashed on the entry!
Old 23-11-09, 12:42 AM   #7
Lozzo
I like Edwinas, it's quite testing. I don't usually like slow corners but it is quite good fun.
Old 23-11-09, 06:35 PM   #8
G
Its fun destroying people who think they have massively out braked you... then they go in way to fast and too deep as you sail past them exiting.
Its defo a slow in fast out corner.
Old 27-11-09, 10:00 AM   #9
Dickyholdsworth
The trouble with slow in at Edwinas is that in a race you just get done on the brakes everytime so it may not be the best thing to do for the exit but you need to brake late and the entry speed you can carry in i have found is unbelieveable! Then just park it mid corner so the guy behind cannot get a run on you coming out, once you have got a bit of space between you and the next guy you can smooth things out and take the ideal line. But to answer the question crashing at Edwinas is very easy to do, you regularly see people run straight on, ( i did this when they first added Edwinas ) or lock the front and crash on the way in, usually because they panic and can't believe they can make the corner, then loads of exit crashes both high and low side, better off without it and go back to the esses proper now that was fun.
Old 27-11-09, 10:38 AM   #10
Dave20046
Dave20046's Avatar
Excuse my ignorance but is edwina's mallory or cadwell? (or somewhere else)
First new test candidate crashes CarlosSV650S Bikes - Talk & Issues 13 11-05-09 08:56 AM
Bike crashes etc ASM-Forever Idle Banter 13 30-07-07 02:35 PM
bike crashes kwak zzr Idle Banter 1 16-10-06 05:01 PM
crashes auldyin Idle Banter 4 13-08-06 09:42 PM
my bike after 9! crashes! socommk23 Photos 8 03-03-06 11:58 PM
