Sorry if this has been done, but a quick search revealed nothing helpful.
Got a pointy 650, need this bike in perfect working order for friday... ... however tonight I thought it'd be a good idea to investigate my weird feeling clutch took the gunged up wormdrive out (worst front sprocket cover *ever*, literally saved a kilo by scraping it out) anyway, short of it is there a three ball bearings missing from the worm drive, I've found two. Questions are: 1) Can I just sit the bearings I've found in place and get away with it? 2)if not, where can I get what I need to fix it ASAP?
Probably get away with it but it might feel a bit scrapy.
Answered the first question myself, it appears to work.
Could still do with buying in a spare wormdrive(?) for under the seat... Is it just the whole worm drive mech. I need or is there just a bearing insert available? Cheers
hehe on closer inspection (with light
I think the actual part wears more than the balls. Think it comes as a lump. Keep meaning to see if the fluid clutch from slabside will fit but not got round to it.
#6 | |
![]() (hell knows why as I trust my hydraulic brakes)
Just space the little bearings around as much as you can so there is equal coverage . On a side note I was tearing my hair out trying to sort mine out in the summer , I`d only fitted it back on the wrong way round ..................doh .
lol nope definitely the right way round, the single tab side faces you (is how I remembered it).
#9 |
The worm drice comes as a whole two part unit when you order from Suzuki. I had to get a new one after loosing more of said balls!
#10 |
Silly question but can't you just pick up the bearings from a cycle shop or something?
Clutch/Worm drive problem | swinging_simian | SV Talk, Tuning & Tweaking | 2 | 05-08-09 01:06 PM |
Clutch worm gear | cammy | SV Talk, Tuning & Tweaking | 3 | 02-08-09 07:23 PM |
Worm Drive | tonybmw92 | SV Talk, Tuning & Tweaking | 15 | 15-08-08 08:12 PM |
Clutch worm drive thing for '00 curvy | Ter | Stuff Wanted | 1 | 16-01-07 04:00 PM |
Clutch release worm gear. | Biker Biggles | SV Talk, Tuning & Tweaking | 2 | 10-12-06 08:43 PM |
