Old 30-11-09, 10:20 PM   #1
touch107fm
Default Stalling at low revs/tickover.
Hi all
My trusting SV 2005 is giving me a bit of trouble. I use it most days to get to work and over the last 2 weeks its started to conk out or turn off at low revs. The worse of it was today when it didnt sound to good from the exhaust. Now I have being meaning to change to spark plugs I have not changed them in a long long time.
Q what do you think is causing my sv to conk out or turn off at low revs. Any ideas.
Would all this rain have anything to do with it. I being driving through some very wet conditions of late.
Any help would be great...
D
Old 01-12-09, 08:03 AM   #2
STRAMASHER
STRAMASHER's Avatar
Default Re: Stalling at low revs/tickover.
Turn your idle up a little until you get to service it.
I run a little higher idle than book as I was getting the odd stall at junctions when cold.
Old 01-12-09, 08:05 AM   #3
Scoobs
Water in the front spark plug is my guess. Commom problem on the SV.
Old 01-12-09, 08:35 AM   #4
Spanner Man
Good morning all.
Ditto H20 getting to the front plug cap. Stick a new set in, & seal the caps. I prefer Holts damp start for this. It dries to a sort of laquer, & has proven over the years to be highly effective.
Also, if you're bike is out of tune, the cold & damp can exacerbate all sorts of erratic running problems, best get it serviced properly.
Cheers.
Spanner Man
Old 01-12-09, 10:29 AM   #5
touch107fm
thanks guys ,,, I am getting the plugs changed this morning will update you on how it goes.
Old 01-12-09, 01:53 PM   #6
BillyC
BillyC's Avatar
Nearly as common as mis-diagnosis
Old 01-12-09, 01:56 PM   #7
BillyC
BillyC's Avatar
Touch - if your bike is stalling at low revs, check the obvious first. If you're idling at anything below 1200 rpm then that's too slow. I believe the figure in the service manual is between 1350 and 1450 rpm.
Check this before mucking around with spark plugs, caps etc.
Old 01-12-09, 02:04 PM   #8
Scoobs
I did say it was a guess young William.
Without seeing / hearing a bike I would never ever say "that is definitely the problem". Just offer advice about good places to start. Now get back in your box before I come to the the smoke and slap you about.
Issue with the tickover Caddy2000 SV Talk, Tuning & Tweaking 6 07-04-09 08:32 PM
No Tickover aermacchi SV Talk, Tuning & Tweaking 3 14-04-08 10:56 AM
tickover pin Hazzar Stuff Wanted 0 09-09-07 04:37 PM
Tickover very variable kumasikid0 SV Talk, Tuning & Tweaking 4 28-07-06 10:29 PM
Popping on tickover Mark_h SV Talk, Tuning & Tweaking 13 17-07-06 06:02 PM
