Old 02-12-09, 08:00 PM   #1
bald git
Default Blood out of a stone
the failure of regulator/rectifier on my sv650x ,99 caused the demise of the ecu,battery, speedo/tachometer and cost me dearly in getting home with bike, inspection by bike shop and purchase of parts to put right. has anyone had a similar fault as i am trying it on with suzuki to get some help with the clocks. would any orgers who have had similar problem please pm me. this is for evidence that a protection design fault exists and the regulator/rectifier is a time bomb, thanks, bg.
Old 02-12-09, 08:13 PM   #2
lee67
Default Re: Blood out of a stone
lmao....suzuki will say thanks but no thanks..reg/rec faults are common on all bikes not just sv's...
Old 02-12-09, 08:18 PM   #3
bald git
thus the title of thread, nothing ventured........
Old 02-12-09, 08:19 PM   #4
lee67
true....GOODLUCK
Old 02-12-09, 08:20 PM   #5
So how did all the other stuff get damaged? Too high voltage?
Old 02-12-09, 08:20 PM   #6
Spiderman
Where the hell am I?
Spiderman's Avatar
you dont know if you dont try, good luck.
I had a reg/rec issue but also had a fair few chaffed wires touching the frame at the same time so i guess my story s useless to you. And also that bike has since been written off so no evidence to show.
Old 02-12-09, 08:21 PM   #7
bald git
spiked with over voltage
Old 02-12-09, 08:26 PM   #8
bald git
i,ve already contacted suzuki, negative reply cause of age, my arguament is bike has 12000 miles for 10 years old. suzukis in warranty period may have covered more than that. better protection for other major comps should be in place. buying new parts to fix and labour could be over a grand
Old 02-12-09, 08:28 PM   #9
Spiderman
Spiderman's Avatar
good argument but you know they will only counter it with "other components" and age. Still as i said above, nothing ventured - nothing gained.
Old 02-12-09, 08:33 PM   #10
bald git
chain of events... reulator packs up...takes out ecu...battery...clocks...bulbs, fuse to clocks did not blow, just feel that a designer could build in better protection that works
stone head hang man Idle Banter 2 03-12-08 08:22 AM
Bellypans & stone chips rob13 Bikes - Talk & Issues 12 06-02-08 10:27 PM
painting stone? hovis Idle Banter 8 01-08-07 05:11 PM
14 stone 8 year old Viney Idle Banter 46 01-03-07 11:05 AM
14 stone how should I set the suspension? Diveboy SV Talk, Tuning & Tweaking 11 06-04-06 12:44 PM
