Old 03-12-09, 11:44 AM   #1
allantheboss
Default 02 Curvy stalls at low revs
I suspect that it's "carb icing". It happens every time I ride my bike to college in the morning, whenever I take off the throttle, if the choke isn't on.
Sometimes however, it happens later in the day as well, after my morning riding, when I would have expected the carbs to have de-iced. Much less frequently, however, but it still happens occasionally. and my bike seems to be on the verge of stalling when I leave it to idle.
Is this just the wild and wacky effects of typical frosty English mornings, dragging out slightly throughout the day?
Old 03-12-09, 11:53 AM   #2
davepreston
Default Re: 02 Curvy stalls at low revs
what is your idle speed at normal (no choke) 1300-1500 if not ajust your settings by turning small black disc left hand side of the engine betwen the two clynders by the frame hth
Old 03-12-09, 01:06 PM   #3
allantheboss
Yeah about any revs below that and it cuts out.. I will try the disc thing later though, left hand side when on the bike? Will I be able to get at it through full fairings?
Thanks a lot for the help! New to biking
Old 03-12-09, 01:08 PM   #4
JamesMio
Yes, left hand side when you're sat on the bike - it's a little black knobly disc which adjusts the engine's idling speed. Sounds like it's set a wee bit low at the moment.
"That **** on the push-bike."
Creatomatic
Old 03-12-09, 01:19 PM   #5
Dave20046
Dave20046's Avatar
For the life of me I can't remeember which way you turn it (gut feeling is clockwise to raise the idle), anyway start the bike up let it tick over, twiddle with the nob (giggidy), give it a rev, let the needle settle (and repeat until you hit the desired tick over speed)
Somewhere around 1200 from memory
Old 03-12-09, 03:59 PM   #6
allantheboss
Where EXACTLY is this disc? I had a brief look (but it was fookin' freezin'), don't want to remove lowers unless I have to to get to it..
Thanks a lot guys
Old 03-12-09, 04:10 PM   #7
fizzwheel
fizzwheel's Avatar
I cant remember exactly, but its on the LHS, It pokes out either just under the fuel tank or in one of the sections of the frame.
Its a black plastic knob, not a disc, somewhere in the area I've put a red circle on in the pic below
Old 03-12-09, 04:39 PM   #8
allantheboss
Yeah found it! Excellent! Ill see if it does its job the next freezing morning we have! Thanks a lot for your help guys!
Old 03-12-09, 08:34 PM   #9
Dave20046
Dave20046's Avatar
Also try filling up with super unleaded.
Old 03-12-09, 08:38 PM   #10
LK-SV
Also try filling up with super unleaded in the winter .....it'll help if it is carb-icing
Finished for you
Stalls with scorpion Baph Exhausts 3 17-05-07 01:11 PM
8k revs and nothing happens!!!! help vsumouse SV Talk, Tuning & Tweaking 15 28-01-07 03:51 PM
Bike stalls when engaging first gear. SVChick SV Talk, Tuning & Tweaking 10 13-02-06 03:57 PM
Stalls and pops Mark_h SV Talk, Tuning & Tweaking 3 25-08-05 04:47 PM
