Old 09-12-09, 03:48 PM   #1
hardhat_harry
Default 180 on an SV
Can a wider rear wheel be fitted to the SV, from say a GSXR?
Is it a good idea?
Ta!!
Old 09-12-09, 03:53 PM   #2
barwel1992
Default Re: 180 on an SV
yes it can be done but theres a lot of work involved like machining the brake mount and wheel spacers, it is usual a gsxr 750 rear wheel that is used not sure which one though
also some people have sead that it make the sv handle worse
Old 09-12-09, 04:31 PM   #3
Aquila
I thought this was a speed thread!!!
Old 09-12-09, 04:46 PM   #4
SV650Racer
If you have an injected bike then a CBR600 1995-1998 model rear wheel fits in. You need to take a few mm from the spacer and then everything just fits in fine. You need the CBR sprocket carrier, sprocket and disc too. Whole lot can be had from ebay for £40-£80.
You can fit a GSXR rear wheel say from a 600K6 but you need to have the sprocket carrier hub machined down to get the sprocket carrier to line up correctly with the chain.
Steve runs a 180 section rear on his race bike and it works very well and improves tyre wear on track as the load on the tyre on the edge is spread over a larger footprint.
Old 09-12-09, 04:52 PM   #5
hardhat_harry
Bugger just sold a set with my Steely
Old 09-12-09, 05:07 PM   #6
plowsie
Bandit 1200 rear wheel fits.
Old 13-12-09, 04:44 PM   #7
Jay-ninja
Just buy an SV1000 and be done with it.
Old 14-12-09, 01:39 PM   #8
Tallguy
Tallguy's Avatar
There's a gentleman in the USA advertising in the For Sale section:
http://forums.sv650.org/showthread.php?t=143904
Pointy K3S in SuperSonicSilver, R&G bungs, Carbon Can Co slip-on SOLD TO MEMBER "Cobra"! So long old friend!
I'm going all Charley Boorman on yo' ass. Can't filter or indicate any more.
Tallguy is offline   Reply With Quote
Old 14-12-09, 03:20 PM   #9
johnnyrod
johnnyrod's Avatar
Sarah everyone says it makes it turn slower, what have you found?
Old 14-12-09, 03:27 PM   #10
SV650Racer
No difference in turn in at all. We are running a 5.5" carbon rim for the dry with the 180 and a CBR 5" rim on the inters and wets.
Turns in great in fact when i rode Steve's SV after riding my supersport bike the SV had me in the kerbs mid corner as it turned so quickly!.
The bike does run a lengthened Ohlins and GSXR front end so quite different to a stock road bike geometry wise anyway.
If your running a 180 on the 5" CBR rim for the road then you will more than likely find it will turn as quick if not a little easier to to the profile of how the tyre sits on the 5" rim.
I ran a 190/55 on my supersport 600 bike for a while and it actually aided initial turn in as the rolling circumference of the tyre was taller than that on the 180/55 so it sat the bike up by a few more mm at the rear and gave a larger side footprint.
