Old 14-12-09, 09:58 PM   #1
gerrymcghee
Default condensation in clocks
I changed a bulb on the rev counter a month or so ago, now I see I have some condensation behind the glass, I know I fitted the rubber plugs okay. maybe mosture got in while I was waiting for the replacements to arrive. Has anyone any hints on how to remove it or is it best to leave well alone.
Old 14-12-09, 10:13 PM   #2
svrich
Default Re: condensation in clocks
Probably got damp when you had it open. You could try opening it up again on a dry warm day (not soon then!) or inside, or putting one of those little moisture absorbing packet things in that you get in shoe boxes etc. My clocks have started doing this too but I know that the case is cracked from my off in March.
Old 14-12-09, 11:01 PM   #3
Take them apart and sort it before anything goes tits up.
If in doubt use some grease around all sealing surfaces and the plugs for the bulbs. Good idea about the silica gel.
sv clocks shane hill Mini-Twins 0 31-08-09 08:19 PM
clocks mkz9876 SV Talk, Tuning & Tweaking 2 30-08-09 01:00 PM
Should headlights (Daytona) get condensation in them? monkey Bikes - Talk & Issues 7 15-10-07 07:36 PM
New can fitted, water or condensation? kciN SV Talk, Tuning & Tweaking 11 23-03-06 05:27 AM
Condensation In Lights Ollie SV Talk, Tuning & Tweaking 5 11-11-05 04:06 PM
