Old 27-12-09, 07:31 PM   #1
allantheboss
Default Newbie question
Alright, I feel like a nob asking this, even though I'm new to biking, but I thought I'd be better off asking than not knowing for longer.
What are the differences incurred by a bike being fuel injected rather than not? And what are the differences between a pointy and curvy otherwise? The paper specs seems pretty darn similar.
Don't say "looks" or "pointys are cooler". But you can say "curvys are cooler"!
Old 27-12-09, 07:50 PM   #2
merlin427
Default Re: Newbie question
A carb' measures the quantity of air passing through it and mixes fuel with it based on sizes of jets which act at different air flows and throttle positions the size of which has been determined for a standard engine setup with standard exhaust/airbox. It also has devices such as an accelerator pump to assist with changing throttle openings the type of carb used on the SV (and most road bikes), a constant velocity, restricts the throttle opeining with a piston/diaphragm which movers as airflow increases to stop the engine 'bogging' if the rider opens the throttle too much. With fuel injection the sensors on the electronic system monitor the contritions and 'turn on' the fuel injector to inject the correct quantity of fuel this. As the fuel is injected much closer to the inlet valves than the carb' allows this improves combustion due to fuel not 'dropping out' of the flowing air onto the inlet tract walls which causes rich or weak running (for short times).
Any changes made to a carb'ed engine need modifications to jets and needles this can be very difficult as modifying a jet to effect one area (part throttle for instance) tends to effect others (such as idle). With FI this can be done by altering the pulses sent to the injector (by plugging in a laptop and possibly using a power commander) and specific areas can be targeted without effecting others.
I prefer FI so my explanation probably favours this system.
Old 27-12-09, 07:53 PM   #3
Alpinestarhero
Ok, fair question, i think you will spark a good debate and discussion about this
So older bikes are more likley to sport carbs - certainly for the SV, they had carbs from 1999 to 2002. Carbs are great because they are easy to understand and work with when they have a problem; its a mechanical object, not electrical so you can pull it apart and twiddle and clean and replace until it works again. Carbs have ben aorund for ages and ages, and therefore can be made to work really really well - it has been noted that carbs generally provide smoother throttle operation than fuel injection. Cheapr fuel injection systems can be snatchy from a closed throttle to just open, but more sophistiacted systems are every bit, if not better, than carbs.
One problem with carbs is the slightly more involved cold-starting, because you need to use the choke. Leaking an engine on choke for too long is bad (the extra petrol washes oil off the bores, causing wear to the engine). A good FI system will sort cold starting out for you itself, hopefully keeping the choke cycle to a minimum to reduce potential wear on the cold start.
One great thing about carbs being mechanical is that if your battery goes completly flat, you can still bump start the motorcycle into life. On an FI bike, if you cant get the fuel rail to prime (indicated by the whirring noise when you flick the ignition to on), then you cant bump start the bike!
Carbs can make an engine a real pig to start in the very cold; the SV has carb heaters, but these need some time to warm the carbs up properly. Until then, you can suffer from a poor running engine, as fuel flow is restricted by the ice forming on the needles / jets (whatever, someone correct me!). FI dosnt have this problem!
I'll let someone else carry on, but hopefully that gives you some food for thought
Old 27-12-09, 07:56 PM   #4
allantheboss
That is pretty darn confusing! But thanks to Merlin!
Old 27-12-09, 07:57 PM   #5
In practical terms not much. FI bikes don't suffer from carb icing, and the choke plungers can't stick - 'cos they're aren't any. Carbed bikes still run ever-so-slightly nicer, but not so much you'd be well advised to choose one over the other.
In practical terms not much. Dimensionally they're pretty much identical, early FI bikes have a slightly higher seat, Curvy rear brake is maybe a bit better than Pointy - but that's only when everything is working properly. Front suspension is as near identical as makes no difference, rear is a different unit but no improvement. Ownership of either is a notably similar experience.
Yes. That's 'cos they are.
If you were minded to buy an SV650, I'd advise to buy the best bike you could find for the money you have, and not fuss over which model that was.
Old 27-12-09, 08:09 PM   #6
allantheboss
At no offence to Merlin, Mr. 'starhero's explanation made much more sense to me! And helps with thoughts I've had about my bike not cold-starting. Is it just a simple case of re-oiling the bores if they've been all washed off? My chokes' been on quite a fair amount when trying to get the bike started. And what are the symptoms of a "poor running engine" because of carb-icing?
Old 27-12-09, 08:16 PM   #7
Alpinestarhero
With carb icing, you'll find the engine wont idle at the correct speed, generally it'll idle very low or just cut out all together. When on the move, you may find the engine dosnt accelerate so easily.
With the whole oil-washed-off-the-bores thing, when the bike is off the choke, then the air-fuel mixture returns to normal, and so the petrol is all burnt off and dosnt "thin out" the oil and hence wash it off so its ok, and as long as you correctly use the choke (keep it on for the minimum amount of time and dont have it on full all the time its on) then it really isnt much of a problem at all
Old 27-12-09, 08:16 PM   #8
allantheboss
So,
Curvy - Slightly smoother on throttle, and can be started on a dead battery
Pointy - Better at cold starting
Old 27-12-09, 08:21 PM   #9
allantheboss
Cool! That makes me less worried. And my engine has cut out many times as soon as I've gotten the engine going, with the revs just lowering until it cuts out, even when I have the choke on. From what you described, this seems like the effects of icing?
I normally can't start the bike again after this. Know why?
Old 27-12-09, 08:33 PM   #10
Alpinestarhero
You might not be able to start the engine right away because of the ice covering the needles / jets (whatever) and not pulling fuel through. You can use a petrol additive called Silkolene Pro FST to help combat carb icing (150-200ml per tankfull of petrol). I use shell V-power fuel instead of standard unleaded which seems to make cold starting less fraught with carb icing. If you can get some, use isopropanol instead of the silkolene pro fst - Pro FST essentialy is isopropanol, but isopropanol is cheaper (or at least it should be!).
HTH
Newbie to all newbie’s and experienced riders / question. tonyk Bikes - Talk & Issues 17 03-06-08 08:12 PM
Newbie with a question! powelly Bikes - Talk & Issues 4 29-07-07 11:05 AM
Newbie Question keystonecane SV Talk, Tuning & Tweaking 6 04-08-06 10:32 PM
Question the newbie Law Idle Banter 19 13-04-06 11:13 AM
A newbie question. Jintel Idle Banter 5 03-03-06 09:29 AM
