Old 28-12-09, 04:53 PM   #1
dynamix
Default 2000 SVS has no power
Hi, after being away for a few weeks I decided to take the bike out. When I tried to start the bike on the electric start the battery was weak and wouldn't start, motor turned but no fire. I recharged the battery and tried again, but the started wouldn't then turn over. I bump started the bike and all was fine until I tried it again the next morning. I had the same issue, ignition on but the starter wouldn't turn.
I changed the battery and now nothing happens when I put the ignition on, no lights or any power.
I have checked the fuses, all seem fine and tried two batteries with no success.
Does anyone have any ideas? May be the rectifier is shot?
The bike has an alarm and immobiliser fitted but is not working now the power is gone.
Thanks
Old 28-12-09, 04:56 PM   #2
Default Re: 2000 SVS has no power
You checked the main fuse?
Old 28-12-09, 05:09 PM   #3
dynamix
is that found under the seat with the ignition fuse and lights?
Old 28-12-09, 05:11 PM   #4
No it is in green casing under right hand infil panel.
Old 28-12-09, 05:27 PM   #5
Mr Speirs
Mr Speirs's Avatar
ah come on, its not that slow a bike.
Old 28-12-09, 05:42 PM   #6
dynamix
Thanks, i'll check this and post an update. Hope it is an easy fix like this
Old 28-12-09, 05:43 PM   #7
Well try the fuse, but these things don't go pop for a laugh. You probably have a broken wire, insulation or connection somewhere.
Old 02-01-10, 03:20 PM   #8
dynamix
Have replaced the main fuse and the power is restored. The starter still dosen't work tho.
Any ideas what this could be related to?
Is there anyway I can test the rectifier to see if there are any problems there?
Thanks
Old 02-01-10, 04:46 PM   #9
Spikenipple
Spikenipple's Avatar
Have you charged the battery...?
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 24-01-10, 05:36 PM   #10
dynamix
I have charged the battery and tried with a jump pack. The power has now been lost again with no response with the ignition on. (No lights or starter)
I have chacked and replaced the main fuse but with no luck this time.
Does anyone know any reason what could cause this?
Sv power jonhunt SV Talk, Tuning & Tweaking 5 08-04-08 07:52 PM
need some more power hookstar SV Talk, Tuning & Tweaking 13 03-04-08 07:12 PM
Bye SV hello POWER!!!! 600+ Bikes - Talk & Issues 9 12-10-07 07:28 AM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
Too much power? caines Bikes - Talk & Issues 24 08-04-05 06:09 PM
