Old 30-12-09, 06:02 PM   #1
skyline
Default Optimate 3 question, yes I am a stupid numpty
Hi all
Due to the the cold weather and the Datatool alarm, my sv battery is now flat so yesterday it was removed (cue the Datatool service mode 15-second beeping ) and hooked up to the Optimate 3.
Come back to it today and the green led is lit up and everything looks fine, so I start to disconnect the charger and in some stupid moment of madness take the clamps off the battery before unplugging the Optimate from the mains. The green led briefly changes to the red "weak" led before they vanish from the display.
After me doing some of this and this and a bit more of this I put the clamps back on and the bottom "recovery" led lights very dimly. I switch the mains on again for the charger and the normal orange charging light is now on and the battery seems to be charging all over again.
I am a ****ing idiot, I really am...and it looks like the battery is now going to be on charge for another night while the bloody Datatool beeps to all and sundry...
My question is that would the battery still be ok after my screw-up? I'm worried now that the battery charging again so soon after the disconnection would shorten the capacity. I've also just remembered I forgot to take out the alarm fuse when taking out the battery, would I still need to remove it and replace when putting the battery back in to stop the alarm spiking?
Cheers for your help all
Old 30-12-09, 06:08 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Optimate 3 question, yes I am a stupid numpty
No idea about your alarm but the battery should be fine.Optimate charged it fully and you have simply connected it up on charge again.It will probably show two green lights in about an hour when it has gone through its cycle.
Old 30-12-09, 06:11 PM   #3
Holdup
Should be no problem at all, if i take mine of and plug it back in instantly the orange light comes back on, i read the booklet and im sure that the orange light is checking the battery (cant remember of the top of my head) its a trickle charger so as soon as it sense's the battery is fully charged it will just switch off again, tbh dont worry about it
Old 30-12-09, 06:18 PM   #4
skyline
Ah thats a relief to know, and in the time it's taken to write my essay above the green light's come up so the battery looks to be ok. Whew!
Cheers loads Biker Biggles and Holdup!
Now to get the battery back in and wrestle with the alarm...
Old 30-12-09, 07:31 PM   #5
skyline
Sorted.
Cheers again!
Next step is to install a weatherproof eyelet lead which should mean no need to remove the battery next time, just plug the Optimate into the lead and charge up.
Old 30-12-09, 07:31 PM   #6
Alpinestarhero
Get or make up a permanent attachment cable from the battery to under the pillion seat, then you can just connect the optimate to this to charge the battery and never faff about taking the battery out
Old 30-12-09, 07:46 PM   #7
thedonal
And if you make them from higher ampage cable, they'll be good for jump starting too (Spanner Man advised that the standard connectors for Optimates won't handle this).
Old 30-12-09, 08:29 PM   #8
fizzwheel
fizzwheel's Avatar
The optimate comes with just such a cable in the box with it, or both the ones I have bought did anyway.
We have Liz's 749 setup that way as the battery is a complete pain in the butt to get it as it requires removal of the fairing.
Old 01-01-10, 11:52 AM   #9
skyline
There is a lead in the box but Optimate now do a weatherproof one with a fuse attachment and a cover that goes over the charger connection. Part TM71:
http://www.accumate.co.uk/it020006.htm
I think you need the fuse on the lead if you have an alarm on the bike? Looking into it at the moment...
Old 01-01-10, 01:30 PM   #10
Originally Posted by thedonal View Post
And if you make them from higher ampage cable, they'll be good for jump starting too.
Whilst it seems initially like a good idea, I wouldn't do this.
The cable needed for the starting current is heavy, and will need to be unfused - unfused electrical items are undesirable, and should be kept to an absolute minimum - for the rare occasions that it will be needed, the risk of whatever insulation the terminals have being compromised and full battery current causing either battery damage or a fire is too great.
If you need to jump start so often that this seems like a good move - fix whatever's wrong instead.
When needing to jump start, for an easy method not requiring access to the battery, do this:
Connect the negative jump lead to a clean unpainted metal part of the frame or engine, take of the right side panel, lift up the green translucent cover over the terminals of the starter solenoid, (where the main fuse is), and connect the live jump lead to the left hand terminal, (the battery terminal - ensure you've got the right one), start as normal.
Doing it this way means you don't have to remove both side panels and the seat - four bolts - only one bolt for one side panel, easy.
Stupid Van Question Sosha Thames Valley 24 30-11-09 08:42 AM
Optimate question Lozzo Bikes - Talk & Issues 4 15-12-08 05:47 PM
Numpty question again....brakes cuffy SV Talk, Tuning & Tweaking 7 27-02-06 04:58 PM
Stupid question??? Ash999 SV Talk, Tuning & Tweaking 1 22-02-05 07:21 PM
Stupid question..... Jabba 2005 Annual Rideout 7 21-02-05 02:24 PM
