Old 31-12-09, 05:50 PM   #1
5hort5
Default TDC on the rear cylinder?
when turning the crank to get tdc on the rear cylinder should the mark in the inspection window be an R or an F? On mine it's an F is that normal? The C and D are the right way up and the arrows are in the right place but i would have thought R stands for Rear, is that not correct?
thanks si
5hort5 is offline   Reply With Quote
Old 31-12-09, 06:08 PM   #2
5hort5
Default Re: TDC on the rear cylinder?
anyone about that knows - I could do with getting the valve cover back on but want to make sure I have down the clearances correctly first.
Old 31-12-09, 06:13 PM   #3
Neeja
Yeah, TDC for rear cyl is on the R
Old 31-12-09, 06:30 PM   #4
jambo
jambo's Avatar
TDC for the Rear cylinder is "R" on the timing inspection cover. HOWEVER, all timing markers for lining up the cams for both front AND rear cylinders use the "F" marker as a point of reference.
Please be careful if you're swapping cams out, not understanding the process completely can quite easily lead to a wrecked engine.
Jambo
Old 31-12-09, 07:02 PM   #5
5hort5
Just doing the clearances and I have measured the rear on F with the C and D centred and the arrows point at the edges of the chain cover thing, is that right?
Old 31-12-09, 07:07 PM   #6
R mark for TDC. But for purposes of what you are doing just look at cams, so long as no valves are being opened on the cylinder you are messing with it is fine, you do not need exact TDC
Old 31-12-09, 07:10 PM   #7
5hort5
Thanks Chris, C and D point up and arrows lining up is good enough for me, off to put some gasket seal on and get this cover back on so I can get **** faced
Old 31-12-09, 07:38 PM   #8
5hort5
ok the results are in for my first ever valve clearance check:
Front Cylinder:
Exhaust:
Left - 0.21mm Right 0.25mm
Inlet:
Left - 0.13mm Right 0.13mm
Rear cylinder
Inlet:
Left - 0.15mm Right 0.15mm
Exhaust:
Left - 0.23mm Right 0.23mm
Now I think that's ok, which would be good
Old 01-01-10, 02:08 AM   #9
jambo
jambo's Avatar
From memory that's everything in tolerance, so happy days, bolt it all back together
Old 01-01-10, 03:25 AM   #10
zadar
You may not get correct reading that way, especially exhaust cam.
To check clearance you use F for front and R for rear or make sure cam lobes point up.
To install cams you use F mark for both front and rear but one revolution apart.
Lean rear cylinder bikerboy998 SV Talk, Tuning & Tweaking 2 16-05-09 10:22 PM
rear master cylinder Bibio SV Talk, Tuning & Tweaking 3 08-05-09 02:40 PM
rear cylinder problem Jaco SV Talk, Tuning & Tweaking 3 25-05-06 08:10 AM
rear cylinder missfire sd1cko SV Talk, Tuning & Tweaking 7 17-01-05 02:38 PM
Q) Why isn't my rear cylinder firing? northwind SV Talk, Tuning & Tweaking 3 05-10-04 05:22 PM
