Old 03-01-10, 10:30 AM   #1
mikelcfc
Default Engine removal tips?
just want to know if theres any alternative to the propper castleated tools to remove the mounting bolts??
cheers...mike
Old 03-01-10, 10:57 AM   #2
fastdruid
fastdruid's Avatar
Default Re: engine removal tips
Taking an angle grinder to a set of appropriately sized sockets. I just got them from some guy off ebay.
Druid
Old 03-01-10, 11:07 AM   #3
Richie
fantabulas
Richie's Avatar
Notice safety goggles!
The Stig does Grinding.
My Flickr photos
Old 03-01-10, 11:15 AM   #4
husky03
its the super heavyweight protective gloves i like
Old 03-01-10, 11:20 AM   #5
Neeja
I used a cold-chisel and a hammer. Worked fine for the two engine removals and installs I've done in the last few months...
Old 03-01-10, 12:24 PM   #6
davepreston
i removed the left (as you sit) bolt first the used a big f off tourque wrench and the bolt came off without issue ,castle nut wasnt touched
Old 03-01-10, 12:27 PM   #7
You can get the engine out without touching the castellated nuts, getting it back in it a bit ticklish though.
If you haven't got a socket to grind to make a tool then you can sometimes use a big chisel like a flathead screwdriver, pop it in end and turn it with an adjustable wrench.
Old 03-01-10, 03:41 PM   #8
As per my post in your other thread. Go through every other possible option before ripping the engine out. Its not as simplez as just pulling it out. You may save yourself a lot of scraped bleeding knuckles, money and time.
Old 03-01-10, 05:26 PM   #9
Biker Biggles
Biker Biggles's Avatar
I did this as well.Im sure its not an approved method and "torquing" them up again the same way even less so.
But it worked for me.
Old 03-01-10, 09:35 PM   #10
Yes, you can be a a bodger and mullah the nuts if you want to, some people may consider this an alternative - I don't.
Make/buy/borrow some suitable tools, when you come to put the motor back in you'll be glad you did.
Swapping out my first engine - any tips? Thirdo SV Talk, Tuning & Tweaking 5 27-08-09 04:12 PM
Any guides on engine removal? breakz187 SV Talk, Tuning & Tweaking 0 17-05-09 07:21 PM
engine removal questions tomjones2 SV Talk, Tuning & Tweaking 2 28-08-06 03:55 PM
Engine Removal - Any Tips anyone? Daimo SV Talk, Tuning & Tweaking 1 09-08-06 10:30 AM
Engine removal question tradedog SV Talk, Tuning & Tweaking 7 20-05-06 11:39 PM
