Old 04-01-10, 08:20 AM   #1
krhall
Default It's Frozen - The key in the ignition!
Ignition barrel was frozen this morning and I couldn't get the key in so after about 3 or 4 mins of breathing warm air into it I managed to get the key in and turn it, pulled up at work 20 mins later and can't get the key out.
Any ideas, I'm sure my warm breath has made the lock wet and now it's re-frozen.
Anything also to prevent it?
Thanks.
Kev
Old 04-01-10, 08:33 AM   #2
krhall
Default Re: It's Frozen - The key in the ignition!!
Would WD40 do it?
Old 04-01-10, 08:45 AM   #3
454697819
should do, yes.
Old 04-01-10, 08:46 AM   #4
rossinio
I had to use white spirit, the wd40 didnt seem to do enough when it was totally frozen..
Old 04-01-10, 08:51 AM   #5
Dicky Ticker
give it a good blast with a hair dryer when you get home and then WD40 IN THE BARREL
Sounds silly but keep a lighter in your pocket and heat the key up if your ignition is frozen.
As for getting it out if frozen in there????? Hot water
Old 04-01-10, 08:57 AM   #6
Dicky Ticker
I know it doesn't help,but as a preventative measure I use the brake additive used on the air braking system of a truck. Little drop in a cheapy plastic oiler squirted into the barrel works every time.
Old 04-01-10, 09:23 AM   #7
Ch00
Ch00's Avatar
Small can of De Icer?
Ch00 is offline   Reply With Quote
Old 04-01-10, 09:29 AM   #8
Grinch
I owned a can of lock de-icer for those really cold days, as its worse when you go to get fuel and find the key won't open the petrol cap.
Old 04-01-10, 11:19 AM   #9
Alpinestarhero
I couldnt get my fuel filler cap open this morning, i assume because of ice! anyway, once opened, I got a load of WD40 in there.
WD40, followed by oil in your ignition lock will do the trick
Old 04-01-10, 11:28 AM   #10
H'mm seeing as the root cause is water getting into the lock, then during these cold days, then perhaps a solid rubber grommet or cap over the top of the ignition at night is going to prevent water getting in there.
The finger off a rubber glove would stretch over and give some protection. This would work for the ignition, but not the tank lock.
Ipod frozen !!! Ratty Idle Banter 18 03-02-09 12:08 AM
Frozen Hands Faisal Bikes - Talk & Issues 41 20-12-08 10:32 AM
Ok, so hell has frozen over... magicrat Idle Banter 11 16-05-08 12:49 PM
Frozen peas sarah Idle Banter 47 10-12-07 08:15 PM
Frozen bike localhost Bikes - Talk & Issues 32 23-11-05 10:42 PM
