Old 04-01-10, 10:29 PM   #1
Scoobs
Default Any Plumbers? Help Please.
Got an Ariston Microcombi 23 MFFI combination boiler. It's just stopped working. Making a loud ticking noise and the heating has just gone off and the hot water doesn't work? Any ideas???
Thanks guys.
Old 04-01-10, 10:36 PM   #2
Rumble bee
Default Re: Any Plumbers? Help Please.
Can you remove the cover, to check if the fan is running?
Chris.
Old 04-01-10, 10:43 PM   #3
Scoobs
Chris.
I can see how to get it off. Can I do this safely with the boiler turned on?
Old 04-01-10, 10:49 PM   #4
Scoobs
Bit more info. Pump sounds like it is running. I've turned the heating off so the ticking has stopped. It sounds like some sort of valve ticking sort of like the click from an electric cigarette lighter but in rapid succession. When I turn the hot tap on, the boiler doesn't "fire up", but the ticking starts again.
Old 04-01-10, 10:53 PM   #5
Rumble bee
To be safe turn off the elec power going to it. Once the case is off and you can see the fan, turn on the power and run the hot tap to see if the fan spins (as its the first part of the ignition cycle). Make sure you don't damage any seals when removing the cover, just be gental.
Chris
Old 04-01-10, 10:58 PM   #6
thermistors??( not sure if your boiler has these), flow sensor?
Old 04-01-10, 10:58 PM   #7
Scoobs
Yep! Fan is working. Doesn't spin very fast though. Is it meant to???
One more thing. It's also got enough pressure. It's at 1.5 bar cold.
Old 04-01-10, 11:04 PM   #8
Rumble bee
On the fan there are two rubber hoses that come of and lead to pressure switch, if you can see which one is positive '+' normally on the casting of the fan alot of the time its red, then pull it off the fan and blow down it, make sure the boiler is on and the hot tap is runing if it lights then its the pressure switch.
Old 04-01-10, 11:11 PM   #9
Scoobs
I'm gonna have another go tomorrow. Getting too late now. I think I'll just go to bed wearing all the clothes I own.
Thanks for the help up to now mate....and welcome to the forum.
Old 04-01-10, 11:21 PM   #10
Rumble bee
Now worries mate, when you have a look tomorrow see if you can see the burner and have a look to see if the burner is sparking. Have you checked the gas, by turning on the cooker or something else gas powerd?
.Org Plumbers? Dave20046 Idle Banter 213 09-04-12 08:51 PM
Plumbers pls advice 600+ Idle Banter 26 29-10-09 10:23 AM
Any plumbers on here? ukgooner Idle Banter 15 27-04-08 11:50 AM
any plumbers/DIY experts hovis Idle Banter 27 01-10-07 08:22 PM
Plumbers help with my new bathroom furrybean Idle Banter 27 06-02-07 09:23 PM
