Old 11-01-10, 02:43 PM   #1
allantheboss
Default Removing Fire Gum
How would one go about it?
Old 11-01-10, 06:40 PM   #2
Default Re: Removing Fire Gum
IME it falls off on its own!
Old 11-01-10, 06:46 PM   #3
Holdup
Use a knife / blade to get the worst off then if u want to get it all off use autosol
Old 11-01-10, 07:58 PM   #4
allantheboss
Ok, with autosol disslove it to bits? Its sealed up tight between the pipes. Basically everything visible has already been chipped away, but there some inside which I need to get out, so I can change my exhaust. I tried just twisting the pipe to crack it, but it wouldn't budge..
Old 11-01-10, 08:01 PM   #5
Holdup
Oh i thought you meant you had the exhaust off already, in that case i dont know sorry
Old 11-01-10, 08:03 PM   #6
allantheboss
Nah, my apologies. I've got a hi-level pipe, firegummed' onto where I cut the original, but I can't fit my bazooka for an MOT at hi-level, so I'll need to take the link pipe off, but it's on there strong..
Old 11-01-10, 08:08 PM   #7
Holdup
Gently hit it with a hammer? wrap the link pipe in a old t shirt or something? might break it away a bit better then
Old 11-01-10, 08:09 PM   #8
allantheboss
Tried it.. Thank you none the less, please tell me if you discover a way!
Old 11-01-10, 08:11 PM   #9
Holdup
WD40 and just keep twisting it then, im sure it will come off eventlually
Old 11-01-10, 11:48 PM   #10
Sally
Get a good MOT tester?
Removing a gas fire Kinvig Idle Banter 10 26-10-09 05:48 PM
Fire in the Sky part II Richie Photos 13 17-10-09 08:41 PM
Fire in the sky. rictus01 Photos 10 12-10-09 11:09 AM
Fire & Ice Kinvig Idle Banter 4 09-11-07 03:37 PM
