Old 11-01-10, 07:56 PM   #1
5hort5
Default Scotty fitting question - pic required
Do you have a scottoiler fitted?
Do you have a camera?
Can you take a picture of how you have the bit on the swing arm and the end that lubes the chain fitted?
Ta - cause I'd like to see how a few have there's before fitting mine
5hort5 is offline   Reply With Quote
Old 11-01-10, 08:04 PM   #2
Default Re: Scotty fitting question - pic required
Here you go. Although there is normally a wheel in there somewhere
Old 11-01-10, 08:16 PM   #3
5hort5
Thanks Darren - are those bolts ones you have added?
Old 11-01-10, 08:25 PM   #4
Yeah drilled and tapped. I had tie wraps before, but it looked **** and never held the pipe exactly where I wanted it
Old 11-01-10, 08:28 PM   #5
5hort5
Nice one thanks Darren - so there's one idea to consider - what else have people done and how have they found it in the real world?
Old 11-01-10, 08:48 PM   #6
ahmedf
When i was considering fitting one of these i was thinking of using sum heavy duty double sided and these
http://cgi.ebay.co.uk/25-16mm-x-16mm...item255665b812
I couldnt drill and tap my swing arm, too scary. Sorry no pics because i ended up oiling my chain the old fashioned way
Old 11-01-10, 09:39 PM   #7
Seggons
Hopefully Lozzo will pop up in here because I personally think he has one of the neatest Scotoiler installs from pics I've seen. I want mine to hopefully look like it at some point.
Old 11-01-10, 09:49 PM   #8
punyXpress
punyXpress's Avatar
Pointed mine at the FRONT sprocket.
Now: Street Triple R
Old 12-01-10, 08:43 AM   #9
speedplay
Makes sense, shorter route for the pipe and easier to hide too
Old 12-01-10, 05:08 PM   #10
jumjum_0214
Does it make less mess pointed at the FS?
Definative helmet fitting guide required! Pukey Bikes - Talk & Issues 4 06-09-09 10:17 AM
Help required fitting a GSXR1000 K6 shock neio79 SV Talk, Tuning & Tweaking 5 10-09-07 07:04 PM
Fitting a hugger - Is a paddock stand required? walnuts SV Talk, Tuning & Tweaking 6 19-06-06 10:32 PM
Beam me back to my crib Scotty. Razor Idle Banter 5 13-06-06 10:03 PM
New Tyre & Fitting required snoopy Soho Massive 5 20-07-05 12:08 PM
