Old 15-01-10, 04:46 PM   #1
Ceebl
Default Broken chain adjuster.
Are the chain adjuster units in a curvies swingarm the same for each year? I have a k1 and the ones on flebay ATM are for a 99 or a k2 I think
thanks org!
Old 15-01-10, 04:47 PM   #2
davepreston
Default Re: Broken chain adjuster!!
yea just not k3 on hth
Old 15-01-10, 04:48 PM   #3
Yes they are.
What do you need? The end cap for the swingarm or the internal chain adjusters
Old 15-01-10, 05:03 PM   #4
Ceebl
My righthand one has always been a bit crissthreaded or damaged and nw iv taken the head off the allenbolt on the left
Old 15-01-10, 05:27 PM   #5
H'mm you'll need to get that allen bolt out somehow, either drill the head off it, or cut a slot in it.
But it sounds pretty stuck, in which case the easiest thing is to take the spindle out and tap the adjuster so that the end cap comes off the swingarm.
Then you can cut the head off the bolt easily
I've got a spare adjuster block in the garage, I might have a spare bolt as well. PM me your address if you need it and I'll get my wife to pop it in the post.
All I'll ask for is the cost of postage
Old 15-01-10, 05:28 PM   #6
Bolt is just a normal M8 anyway IIRC. Sure I've put some stainless in there for someone at some point. (photographic memory me LOL)
Old 15-01-10, 05:34 PM   #7
Yes, I've got S/S plus I greased inside as alu + steel adjuster is a good recipie for rot
Old 15-01-10, 09:32 PM   #8
warrenhewitt10
Default Re: Broken chain adjuster.
maviczap, i approve of your avatar photo........that is all
Old 15-01-10, 09:37 PM   #9
Its my Missus
Old 15-01-10, 10:05 PM   #10
davepreston
she called april
chocolate chain adjuster plates dmracing SV Talk, Tuning & Tweaking 6 01-08-09 09:23 PM
Chain adjuster plates dmracing Stuff Wanted 6 24-07-07 05:54 PM
Cam chain adjuster gasket SDMF SV Talk, Tuning & Tweaking 5 09-07-07 06:31 PM
chain adjuster problem steveg SV Talk, Tuning & Tweaking 6 11-09-06 06:01 PM
Chain adjuster seized. Scoobs Bikes - Talk & Issues 24 05-03-06 06:55 PM
