Old 16-01-10, 07:22 PM   #1
lawson17
Default Replacement wheel bearing tolerance.
Hi, just after some orgers opinions really...
I ordered a set of bearings to replace the ones in my pointy front wheel, from an online motorcycle patent parts supplier.
They arrived today, 6203 2RS's, but they are C3 rated! (More internal clearance) Is it worth putting them in or am I going to be wasting my time? They feel as though they have more play in them than the ones I took out!
Any opinions would be appreciated!
Thanks
Lawson
Old 16-01-10, 07:43 PM   #2
Default Re: Replacement bearings
Bearings are, as I'm sure you know, rated by clearance between C1 and C5. 'Ordinary' bearings, (if there is such a thing), would be CN, which is midway between C2 and C3.
C3 is fine - you wouldn't want to run a close tolerance bearing at high speed.
Old 16-01-10, 08:22 PM   #3
lawson17
Default Re: Replacement wheel bearing tolerance.
Thanks Sid Squid!
wheel bearing covers barwel1992 SV Talk, Tuning & Tweaking 6 05-11-09 10:05 PM
650 k3 wheel bearing numbers shiver85 SV Talk, Tuning & Tweaking 4 01-10-09 07:24 PM
wheel bearing service interval? doser SV Talk, Tuning & Tweaking 11 27-08-09 09:32 AM
Wheel Bearing Inner Race Removal: MrMessy Bikes - Talk & Issues 11 15-11-08 10:04 PM
K3 rear wheel bearing sizes chunkytfg SV Talk, Tuning & Tweaking 10 10-04-06 06:49 PM
