Mini-Twins Goto Minitwins Official Site
Old 17-01-10, 10:47 AM   #1
pjowo2
Default Engine rebuild/Tuning for Manx Grand Prix
Hi
Can anyone give me advise please on the following I need to prepare my 2005 injection MiniTwin for the MGP and some Irish rounds
Engine
do I need to do anything with the crankshaft ?
what conrods ?
which pistons ?
which cams ?
do you skim the cylinder heads to raise compression ?
do you do the 3 angle cuts to valves and seats ?
what cylinder head gasket do you use ?
do you change the valves ?
is the standard clutch ok to use ?
what else can be done to give a reliable 80+ BHP ?
Chassis
which model GSXR600 USD front forks to use ?
Thank you Paul Judge (Swift Racing)
Old 17-01-10, 10:57 AM   #2
Default Re: Engine rebuild/Tuning for Manx Grand Prix
From my reading around the subject I would start with a 1gen engine, fit some OEM busa pistons, do the cam swap and either fit flatslides or bore the throttle bodies out. Add a leo vinci system. This should get you in the ball park.
TWFforum try here
Forks I would use the K4 ish ones, can't remember offhand but the newest that still had the high flow type valves. If you're going to be getting them revalved then it doesn't matter much I suppose. Edit: it is 06 and newer which does not have high flow valves
Old 17-01-10, 07:22 PM   #3
Wizzbangwill
Speak to the experts - sv650racer on here or her husband Steve Jordan who does lots of motors for the Irish and Manx roads. He runs poss the trickest sv in the country himself so knows what is worth it and what isn't from experience rather than just Reading forums!
Old 18-01-10, 12:06 PM   #4
SV650Racer
Originally Posted by pjowo2 View Post
Hi
Engine
what conrods ?
which pistons ?
which cams ?
Chassis
Hi Paul..long time no see, hope your well!.
If your about give me a call at the shop and can run through whats worthwhile and what isnt. Plenty of options available dependant on what budget you will be running the bike on. Steve has done lots of 650cc 82bhp bikes for the roads running well within the reliability band and on a fairly lowish budget too.
I guess you still havent got the R6??..
Old 18-01-10, 09:23 PM   #5
pjowo2
Hi Yorkie Chris, Wizzbangwill, SV650Racer
Thank you all for your replys and advice
Hope you and Steve are well Sarah havent seen you both for ages, I have sold my R6 to Chris Bradshaw who Races on the roads also, I need to get some advice and get cracking ASAP, Sarah when would be a good time to call you ?
Thanks alot Kind Regards Paul.
Old 19-01-10, 09:02 AM   #6
SV650Racer
No probs Paul. Im at the shop all day. I will also PM you my mobile number just in case you cant ring during the day.
Fast SV 650 at Manx Grand Prix Wild Bill Racing and Paddock Chat 1 22-08-08 04:54 PM
BBC Sport: Conner injured in Manx Grand Prix NewsBot News 0 30-08-07 09:10 AM
BBC Sport: Manx Grand Prix will take place NewsBot News 0 09-08-07 09:50 AM
Ulster Grand Prix yvo6 TOTALSV Ireland 0 24-07-06 08:15 AM
grand prix madmal Idle Banter 21 13-03-06 09:51 PM
